Can anyone give me the correct procedure for replacing the cooling fan assembly in a 2008 XC70. 850's and V70's seem well documented, but not the P3 platform XC70. The fan assembly seems to be designed to come out through the top of the engine compartment, but it's so tight, I'm guessing that something else would need to be disassembled in order to make it possible. The space below the engine compartment seems too small relative to the thickness of the assembly for it to pass through. Any insight would be greatly appreciated.
Thanks.
2008 XC70 Procedure For Replacing Cooling Fan Assembly
nickalos
- Year and Model: 2008 XC70
Revitalizing this thread.
Did a keyword search for "cooling fan" in this forum and only pulled up 6 results. Anyone have any experience with this since the OP posted this in 2015. I'll be doing this next week.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
1. Remove the intake manifold (replace the thermostat and small coolant hose at the same time)
take a look at this link for help http://www.freel2.com/forum/topic32245.html
2. remove and replace the fan assembly
It seems really easy....its not
Good Luck
Paul
PS if you get a chance post some pics after your done to help the next guy out
Good Luck
Paul
Hello !nickalos wrote: 23 Aug 2018, 12:18 Revitalizing this thread.
Did a keyword search for "cooling fan" in this forum référenceur freelance paris and only pulled up 6 results. Anyone have any experience with this since the OP posted this in 2015. I'll be doing this next week.
I’m a new member here and I think that this site is a very good one because there are many different subjects and various tips!
- 1912 Views
Last post by ndjalva
- 8293 Views
Last post by jgpineault
- 7964 Views
Last post by wasaabi
- 619 Views
Last post by AlanP64
- 757 Views
Last post by m96ag
