1999 V70T5m56, centric parts quality?, rear wheel bearing squeak 271795
Has thanked: 292 times
Been thanked: 765 times
Re: 1999 V70T5m56, centric parts quality?, rear wheel bearing squeak 271795
You go through a lot of bearings. I've still only replaced one on all my p80 cars, a rear, and that was by mistake (it was the brake shield, not the bearing). Must be that jerky clutch pedal foot!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1498 times
Been thanked: 3810 times
In at 1100, out by 1300
Here is what I found
211800
Went in to investigate squeak in left rear wheel, occurs after 20 minutes highway driving, wheel rev dependent, changes on side to side loading
Found right parking shoe completely delaminated
Left parking shoe down to 2mm
replaced left rear bearing with Centric from FCP
Textar parking shoes and hardware
Possible left rear caliper freezing up - inboard pad is worn to groove
Source new caliper, pins, hardware, pads.
Tool notes
36 mm socket for rear hub nut. 120 Nm +30 torque Single use nut.
Rear caliper bolts M8
Document Parking shoe install procedure
Loosely mount shoes - do not put into brake plate clips yet.
insert and pin lower spring
Insert brake adjuster into top, insert upper spring
Insert shoes into clips
Using screwdriver as level, pry shoes into lower grooves.
Pop off the cap, 36 mm socket for the nut
Nice quality hardware
Parking brake shoe layout
Needed puller for one drum - user error
One side fragmented, the other side delaminated..
Shiny new clips M8 on top, catch on bottom
Easier to do top spring last, I found
All good
All good
Stand by for pictures
I might have been fooled by the brake shoes on this car. I did replace the wheel hub and bearing with the centric brand one due to the noise evidence, but the whole thing could have been a sticking left rear caliper which has taken one brake pad down to the slot, inboard.
Note
Volvo calls for a new nut on the rear hub replacement
Part number 9200250, $10 part
I calculated the 120 Nm plus 30 degree torque Is well below the elastic limit, so I reused it and punchmarked it,
After 2000 miles, no motion.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
For the record I used a GMC front wheel bearing on our 2006 XC90 upon purchase; still quiet after almost 20,000kms. I didn't like that it didn't come with new bolts but that's what to expect at about 1/4 of Volvo's.
Just as well you checked those linings well done!!
Update
Now 20k on the centric rear wheel bearing with no sounds or problems
Added rear wheel nut (FWD) part number up thread)
At 233xxx miles maybe Textar rearbrake shoes have worn out. Hmmm I do run them tight since it’s a stick car and the parking brake I still important, but that life sucks, 22 k miles
Had a hard time replacing the right rear rotor. Had to grind off the lip with a Dremel and was still really tight. Left one easier.
New Shoes were ATE from FCP. I’ll order new ones for stock as I have three cars that use these now
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
there is no wear on the parking break shoes since the car is never moving when applied un less you are using it to break loose the rear when drifting corners. the cable must be sticking.
:oops: Uh, I might do a few drifts into parking spaces in the winter
:oops:
