Air Guide Deflector, Grille, and Bumper Parts
titanvolvo
- Year and Model: V70 2004
Hello! I'm searching for the part number for the front Air guides, that go below the bumper of my 2004 V70 2.5T. I need the lower, black, plastic grille that mounts in the lowest spoiler in the front bumper/air opening. It is the part that is in front of the radiator sheild. I brock mine when I hit a coon in the dark.
- RickHaleParker
- Been thanked: 979 times
#46 is Volvo part number 31373992.
After you look up the price, you might want to head for a Pick-n-Pull for a good used one.
Active
Past
Past
There is an aftermarket one from Swedish parts that fits , maybe after some massaging. Running one on the P2
titanvolvo
Guys, that's not the part, I know the info for the skid plate. I need the part number for the black plastic grill in the lower part of the bumper. this part is not pictured in the diagram posted above. Is it part of the bumper assembly? Anyone have a parts diagram for the bumper covers and fins?
Have you tried my favorite parts exploder, Volvo Parts Lisle?
Put your VIN in and see if you can find it there?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
If you mean the horizontal bar inside the lower opening it's part of the front assembly.
Or do you mean the plastic cover just in front of #46 pictured above. Covering the bottom of the radiator?
titanvolvo
Is this part the same as the rear part of the front bumper? Grille is all part of the back support?
titanvolvo
No it is not, I bought the rear assembly and the grill is not part of that. What other exploded diagram should I look at to find the number?
- RickHaleParker
Take a picture, circle what you need then post the picture here.
Active
Past
Past
- 766 Views
- 9111 Views
Last post by IronMike
- 1049 Views
- 504 Views
Last post by monsanti30
- 2820 Views
Last post by [email protected]
