2006 Volvo XC90 won't go into park
woodg
Year and Model: 2006 S60 T5
Post by woodg »
I recently had my XC90 refuse to go into park. I have been getting nowhere with this, can't find anything about it online.
I had a mechanic tell me that the shifter assembly probabaly needed to be replaced. I've ruled that out by removing the assembly and moving the shifter cable by hand. I've also moved the arm that the other end of the cable is attached to and even when it is in what appears to be the park position, the pawl does not engage and the car can be moved. The shift position indicator light on the console shows that it is in reverse.
Could this just be a shifter position switch adjustment?
Thanks in advance for your help.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 126 times
Post by ggleavitt »
TF-80SC Shifter cable adjustment.pdf
(247.87 KiB) Downloaded 825 times
Procedure for cable adjustment if this is your issue.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
woodg
Post by woodg »
Thanks. I believe I've already determined that the issue is not an adjustment. I have disconnected the cable from the shifter assembly and the lever is in the full forward position, but the car will still roll. I can count the position detent positions but the parking pawl is not engaging.
I'm not sure if something is broken internally or not. If I put it all back together, it will drive normally. I just can't get it into park.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
ggleavitt
Post by ggleavitt »
cool, then at least the cable moves in some sort of alignment with gear selection.
Now's where I start making a guess but I wonder if the shift interlock works both ways (out of park, into park). If it's an interlock issue, can maybe start with the solenoid. Put your hand over the top front of the shifter cover with ignition switch in POS II (engine does not need to be running) and press the brake pedal. Do you feel the solenoid moving? Might be subtle but you'll feel it if you do it a few times. If this works, then it's probably best to open everything up and see where the travel is restricted in the shifter assembly itself. If it does not move, you have a good place to start investigating (stuck solenoid, brake pedal adjustment, etc.).
You can take the key out of the ignition? I'm guessing no since the car won't go to Park. Possible that the mechanical interlock (ignition key cylinder to shifter) has an issue but let's try the simple stuff first.
Let us know what you find.
Thanks
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Did you detach the cable from the lever on transmission and move the lever to see if you can get it into P?
That it isn't in P and you say the indication in DIM says R tells me it isn't physcially getting into P position.
Once cable is off the lever but shifter inside is in P, push and pull on the cable to see if there is some give there.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
What engine do you have in the 2006 XC90? From that I can try to pull up what transmission you have.
woodg
Post by woodg »
jimmy57 wrote: 30 Aug 2018, 11:40 Did you detach the cable from the lever on transmission and move the lever to see if you can get it into P?
Yes the shifter will not go into park with the cable disconnected from the assembly. I tried shifting it into park at the arm at the other end of the cable, but it won't go past the Reverse position. Although it is not running at the moment due to having the shifter taken apart, when it is as far forward as it will go, the reverse lights at the back of the car are on. It seems to me that there is some mechanical issue that is blocking the arm from going all the way to where it should be.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
woodg
Post by woodg »
SuperHerman wrote: 30 Aug 2018, 20:58 What engine do you have in the 2006 XC90? From that I can try to pull up what transmission you have.
3.2 L
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
woodg
Post by woodg »
I didn't detach it from the transmission end, but I did move the lever when the other end was disconnected from the shifter assembly.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
jimmy57
Post by jimmy57 »
after you did that it indicated R when you moved it as far as you could?
