Secondary air
Hateprojects
Year and Model: 98 volvo v70
Has thanked: 6 times
Post by Hateprojects »
My secondary air pump is not switching on when the diverter valve opens. The pump is good. I have ran it by pushing the contact points closed at the relay.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Did you check the coil on the relay? The relay won't switch if the coil is open.
Active
Past
Hateprojects
I will start with that. It's setting next to the exact same relay, I'll swap them.
Hateprojects
Ok swapped relay, relay is not thethe problem.
