Rollover Valve Topic is solved
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
Rollover Valve
Yesterday while replacing rear endlink bushings on my 1994 850 NA 172K I broke and end off what I found out to be the rollover valve. Can I scrap this valve and just connect the inlet and outlet hoses together? Will it affect antything? Tip. I used a 3/16 2 flute x-long end mill in a drill to hog out the rubber and plastic, no heat, each side took about 45 mins. A couple shots with a hand sledge and pipe from behind on lower lip of bushing and they dropped out. Any input on rollover valve would be greatly appreciated. Thanks
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Yes you can,but you will not have a roll-over protection from fuel escaping anymore.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1505 times
- Been thanked: 3818 times
More importantly, it stops this from happening - wear your seat belts too...
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
I don't understand how the rollover valve actually works, since it's not on the fuel line. I replaced the decayed hoses on mine (1/4" ID silicone fuel line for small engines from O'Reilly Auto), but can somebody explain how it stops the flow of fuel.
Related, there's another small device just ahead of the rollover valve on my 96 850 NA that seems integrated in the fuel line and has a short "J hose" connection to what I assume is the vapor line. What is that device?
- GlennG2759
After just taking mine out today and replacing with hose, it seems to be a very simple check valve. When turned upside down (in case of a rollover) I believe it interrupts the flow of fuel by way of the fuel tank venting system. Just a guess though. That other device on your 96 could be the purge valve. My 94's located above radiator fan in shroud. Although I've done a lot work to my 94 850 in short time I've had it , I'm a newbie to volvos. I find their engineering amazing.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I think the rollover valve is designed to close when the car is tilted or upside down. The closing prevents liquid fuel from the tank from escaping through the vent tube, which could happen when the tank gets tilted or flipped upside down in an accident.
JimBee
I had mine off, so I could hear the ball valve inside when I tilted or inverted it.
It makes sense that it somehow would create a vacuum, but if the tank isn't full, would there be enough negative pressure on that line, from the valve to the tank, to pull a vacuum on the empty space in the fuel tank and preventing fuel from finding an outlet?
