Which auxiliary power relay to replace? Topic is solved
charleyc
Year and Model: 1998
Post by charleyc »
Original owner of 1998 S70 with 332k miles. Car starts, headlights are on, fuses good, but radio, windows, heater fan, wipers all won’t go on. Which relay am I looking to replace? Or is it a worn out ignition key switch? Thanks for your ideas!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
All of them in the same time to go bad....i would say...ignition switch.
I guess that you allready checked the fuses.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If you suspect an aux relay, I believe that 2/30 is the one you want.
It’s called out as 105 on the attached chart. It can be swapped with
the adjacent 106 relay to confirm your theory.
charleyc
Post by charleyc »
Perfect, thanks! Will swap out 105 and 106, and then hopefully find it's only a relay and not the ignition key switch. Report back next Monday.
charleyc
Post by charleyc »
Thanks for advice all. Turns out the ignition key switch assembly is starting to fail. You can wiggle or turn the key a bit and aux power is restored to all. I can live with it for a while....
misha
Post by misha »
charleyc wrote: 10 Sep 2018, 14:13 Thanks for advice all. Turns out the ignition key switch assembly is starting to fail. You can wiggle or turn the key a bit and aux power is restored to all. I can live with it for a while....
misha wrote: 05 Sep 2018, 13:46 All of them in the same time to go bad....i would say...ignition switch.
:wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
