Computer Safe Automotive Logic Probe.
Attach clips to starter battery. Touch tip to point to be tested.
If the tip is high ~12V (Hot) the led lights Red.
If the tip is low ~0v (ground) the led lights Green.
A tools show off thread... ?
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
- Has thanked: 316 times
- Been thanked: 531 times
Another one of my favorites as far as Harbor Freight stuff, I recently picked up a 1/4" Pittsburgh Pro slim head ratchet because my Craftsman 75 tooth began seizing up (6 months old!) and I'm glad I did! It's incredibly smooth and built really well. It holds sockets nice and tight and the length of the handle is perfect. Their pro series (red/black comfort grip) ratchets are some of their best tools. It's definitely my new favorite 1/4" ratchet!
My only complaint is the directional switch is very easy to move, which could be problematic in tight spaces when it could knock against something. It sticks out too much, which I don't like. At least they made it so it swings further up in either direction to avoid accidental movement (something they don't do with their quick release chrome ratchets) but it only does so much. The switches on my Duralast ratchets are much better.
https://www.harborfreight.com/14-in-dri ... 62329.html
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Why is "Tool #4" in the Volvo timing tool kit needed? They press against the valve springs so the cam cover goes down square?
- Has thanked: 2864 times
- Been thanked: 1332 times
Ratchets that reverse direction because of a poorly designed switch are the worst.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
bmdubya1198 wrote: 09 Sep 2018, 07:51 My only complaint is the directional switch is very easy to move, which could be problematic in tight spaces when it could knock against something. It sticks out too much, which I don't like.
nothing a grinder cannot fix - speaking about the bump on the switch
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Yes, to help it go down evenly. I also suspect it makes things a bit easier on all the cam cover bolts if you aren't actually relying on them to push the cam cover and valve springs down. I didn't have this when I did my cam cover jobs, so I just relied on the bolts to do the pulling together, but I would have rather used it.Georgeandkira wrote: 09 Sep 2018, 09:01 Why is "Tool #4" in the Volvo timing tool kit needed? They press against the valve springs so the cam cover goes down square?
Cars I've owned:
- RickHaleParker
Yes #4 works against the valve springs and lifters.Georgeandkira wrote: 09 Sep 2018, 09:01 Why is "Tool #4" in the Volvo timing tool kit needed? They press against the valve springs so the cam cover goes down square?
1. Holds the cam cover true to the head.
2. Spreads the liquid gasket evenly.
3. Locks the O-rings in place.
4. Vertically aligns the holes in the head with the holes in the cam cover, minimizing the odds of cross threading.
5. Facilitates even torquing of the bolts across the cam cover.
If you install the cams to the cover using #2 & #3, the valve springs and lifters pressure against the cams and cover is at the minimum and the camshafts are aligned. Do this with the crankshaft aligned and you need not worry about bolting down the cam cover with the timing in an interference condition. Everything will go together aligned and in time.
Active
Past
Past
That is true!oragex wrote: 09 Sep 2018, 11:09 nothing a grinder cannot fix - speaking about the bump on the switch![]()
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Low profile ratchet from HF.
It fits where most dont.
Not comfortable in the hand but a blessing when you gotta have it.
Both 1/4 and 3/8th ends, flex head, button release.
I've heard good things about that low profile ratchet. A HF gem. That's one I'd like to get at some point.
- 2745 Views
Last post by matthew1
- 9 Replies
- 13039 Views
- 11 Replies
- 19525 Views
Last post by volvolugnut
- 1270 Views
Last post by RickHaleParker
- 1622 Views
Last post by JRL
