How exactly do I tell if a front strut has gone bad?
I replaced the front struts three years ago, summer of 15, with Sachs 9140072 from FCP Euro. I replaced the strut seats and sway bar linkage at the same time. Car has been off to college with my kid for a couple years. Kid came home for a visit and I drove the car to work today. I hear definite squeaking from the left front end when going over minor bumps. When I push down on the front of the car in the driveway, the front left car moves down a lot easier than the right front. I'm going to change the oil tonight, anything I can look at underneath while I have it jacked up to verify the strut is kaput? And shouldn't struts last longer than three years?
1996 850 Turbo - Bad front strut.
- Has thanked: 311 times
- Been thanked: 817 times
That all fits a bad spring seat on the left side, except the "a lot" part of "a lot easier." Anyway maybe that's all that has gone bad, which would not be surprising for 3 years. Give the top nut a spin.
Yep, that's it. Everything looked good from underneath. I can pull the top of the strut up a good half inch or so, and spin it freely.
Do I have to remove the strut to replace the top seat?
https://photos.google.com/share/AF1QipO ... Q3OW5RSDRn
The aftermarket ones give you the joy of repeating the job every 12 months. FCP will give you new parts, and you get to do front strut work in the middle of a blizzard, outside.
OEM VOLVO are the parts that last here.
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
$100? I think you need spring seats not strut mounts.bugs11 wrote: 09 Sep 2018, 11:39 Which front top strut mount is recommended? The INA or BOGE from FCP Euro. Genuine Volvo is about $100 more than those two.
You need this: https://www.fcpeuro.com/products/volvo- ... p2-8646713
not this: https://www.fcpeuro.com/products/volvo- ... t-31200599
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
Is it time for a cabin filter yet? Oil cap rubber gasket?
Even the Volvo spring seats are suspect now as they appear to have switched manufacturures and some have seen early failure (thread somewhere around here ...) but that's what I would by, and hang onto the FCP warranty if/as needed. Unfortunately you have to disassemble the whole strut assembly to replace the spring seat. Spring compressors, etc..
- Has thanked: 2200 times
I have used Sachs spring seats and they seem to be ok. Volvo now uses Rein which are not as good in my opinion.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Sachs spring seats are cheaper on FCP. If Volvo really did switch to Rein, then I would buy Sachs. If you have to replace them within 2 years either way, then why not save some money?
Knows enough to be dangerous
- 12 Replies
- 2798 Views
Last post by greg850r
- 11 Replies
- 7974 Views
Last post by BackRoadSeeker
- 2319 Views
Last post by oragex
- 1154 Views
Last post by BigRed
- 345 Views
