Hey guys, trying to find a replacement coil harness. When I was replacing a spark plug, I pulled off the connector to the coil pack and must have pulled out a wire from the connector.
Does anyone have a part number? I can’t find one.
2007 v8 ignition coil harness replacement
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Search Ebay for "denso ignition coil connector" I think the first one tht comes up with connector, 4 terminals, 4 rubber wire seals is the right one.
- RickHaleParker
- Been thanked: 979 times
Hold your horses, harness are real expensive, replacing a harness is a last resort.
Did the metal pin come out of the connector or did you break the wire off at the metal pin?
Active
Past
Past
xiphosm3
- Year and Model: 2007 XC90 V8 Sport
The wire broke off from the metal pin. The pin is still stuck inside the connector.RickHaleParker wrote: 09 Sep 2018, 19:18 Hold your horses, harness are real expensive, replacing a harness is a last resort.
xiphosm3
What about this? https://www.amazon.com/GooDeal-Connecto ... 942EXC4F8Ajimmy57 wrote: 09 Sep 2018, 19:00 Search Ebay for "denso ignition coil connector" I think the first one tht comes up with connector, 4 terminals, 4 rubber wire seals is the right one.
jimmy57
I don't have a V8 to look at so you are the better positioned to know. The replacement connectors may be different color for some of the bits but that would make no difference. I think they are correct from memory.
- RickHaleParker
Xiphosm you could spend a lot of time on this OR you could:
1. leave the coil and fuel injector disconnected
2. Drive it to a independent shop that specializes in automotive electrical.
3. Have them extract the pin and install a new one.
4. Be done with this.
The bill should not break your bank account.
Yes there are pin extraction tools that can get the pin out and replacement pins can be bought but sourceing them can be too time consuming for a one time deal.
Active
Past
Past
