On my 94 T5M the gears go in alright, but slow shifting is the key. Would the gears go in smoother and quicker with new fluid or would I rather risk ruining the tranny?
I guess Volvo claims a lifetime fill.
Do we change tranny fluid in M56s? Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
1996 855 R,
2010 V70 D5,
2010 V70 D5,
I changed mine about 2 years ago. I think it did make shifting nicer in winter.
I used Valvoline synthetic gear oil - its a pretty big odd size bolt - maybe a 21 or 22mm?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I changed mine with an engine swap at about 229 k. Oil that came out was, according to my mechanic, pristine. He said he wouldn't have changed it. I don't think you'll hurt anything (but I used the ridiculously expensive Volvo gear oil) -- I would have sold Steve my used stuff. . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
When I did the clutch replacement in my old '96 GLT, I used Redline MTL in the trans. I've had good luck with it in other vehicles in the past, and it seemed happy with it.
- Year and Model: Many Volvos
- Been thanked: 76 times
I had about 230k on mine when I changed the clutch and changed the fluid at the same time. Volvo wants a GL4 and I used a Royal Purple that said GL4 on the bottle but it was actually GL5 that covers the GL4 spec. The only issue I had was that it was "notchy" when it was cold and I think the issue is that GL5 is actually too slick and it doesn't give enough drag for the synchros to work as they should. It wasn't bad but if I had to do it over again I would go ahead and bite the bullet and buy the Volvo stuff.
One suggestion that was provided a couple of years ago, remove the upper fill plug first. I think the suggestion was from experience on that one and if you can't get the fill plug loose, and you have already drained the transmission, then you are a bit screwed.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I'm about to replace my clutch. Thinking about replacing the gear oil since it has 265k miles on it. Was looking at buying gear oil, and volvo's stuff was just as "cheap" as whatever you could buy at an autoparts store. I wouldn't consider $18.78 per liter expensive for gear oil.
Knows enough to be dangerous
- Clemens
How many liters or quarts or pints or whatever go in there? My VW bus has only 2 and something liters in there, so I guess 2-3 liters.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
I don’t think I used 2 whole liters, Clemens
Bumped the thread, under 2 liters
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I replaced the gear oil on my P2 a while ago with Redline MTL, which is GL-4. I was hoping that this change would make shifting in cold weather a little easier but it made no difference. Especially going into reverse is hard to do on this car, even when it's warm.
Anyone know what's going on or how to fix this?
Thanks, Dirk
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 13 Replies
- 3933 Views
Last post by mrscullini
- 26 Replies
- 5498 Views
Last post by Georgeandkira
- 1726 Views
Last post by sacricide
- 9 Replies
- 1953 Views
Last post by johngxc
- 1317 Views
Last post by JimBee
