Did you know? 🤔
Cabin Air Fan Speed Varies
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
drewmeister2
Year and Model: 2009 S80
Has thanked: 0
Been thanked: 0
United States of America
drewmeister2
Post by drewmeister2 » Sat Sep 08, 2018 9:41 am
I've noticed that the speed of the cabin air fan varies intermittently on my 2009 S80, for no apparent reason (regardless of whether I'm accelerating, at idle, at a constant cruising speed, whether or not I'm recirculating air or taking in air from outside, whether using the A/C or heat). I've taken it in to the dealer (I have an extended warranty), and they found no trouble codes, so they didn't do anything. I replaced the cabin air filter, which did not help.
Anyone else experienced this? Also, I have a month left on my extended warranty. Do I have any basis for pushing the dealer to replace whatever part might be causing this, even without a trouble code?
Has thanked: 192 times
Been thanked: 620 times
Trinidad & Tobago
Re: Cabin Air Fan Speed Varies
Post by abscate » Tue Sep 11, 2018 11:04 am
It will vary according to heat load, solar load, speed of car - to maintain the cabin at the setpoint.
Does it vary if you set the fan button in the middle of the range?
oragex
Year and Model: S60 2003
Has thanked: 81 times
Been thanked: 177 times
Canada
oragex
Post by oragex » Tue Sep 11, 2018 11:07 am
Does it also vary in manual mode? P3 models have issues with the blower regulator www.youtube.com/watch?v=z-9SKu49LBE
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
drewmeister2
Has thanked: 0
Been thanked: 0
drewmeister2
Post by drewmeister2 » Tue Sep 11, 2018 4:42 pm
This is in manual mode, I don't usually use auto. It doesn't seem to matter regarding any variables. It will be normal speed, blow hard for a second (maybe half a second even), then go back to its set speed, maybe slow down for a second, then back to set speed, etc. This happens at all set speeds.
jimmy57
Has thanked: 2 times
Been thanked: 154 times
jimmy57
Post by jimmy57 » Tue Sep 11, 2018 4:51 pm
No noise? That is something I have seen with the blowers on those cars before they go out. Usually they make a high pitched squeal. I don't always hear the squeal but females do. Ladies have better hearing range than men.
drewmeister2
Has thanked: 0
Been thanked: 0
drewmeister2
Post by drewmeister2 » Tue Sep 11, 2018 5:07 pm
Yeah, no noise. My wife can't hear anything abnormal (other than the varying fan speed). I guess I'd like to know if anyone knows what might be the cause, but also, if I have any justification for demanding a new blower without any trouble codes. I guess it's hard to say exactly what to replace though without any trouble codes.
mrbrian200
Has thanked: 7 times
Been thanked: 75 times
mrbrian200
Post by mrbrian200 » Tue Sep 11, 2018 5:41 pm
Who would know this (I'm not sure)...
Is the output from the regulator to the fan motor high frequency PWM or true DC (variable)?
How to proceed would depend on this difference and whether you have access to either a voltmeter or oscilloscope depending. Voltmeter for DC, scope for PWM.
oragex
Canada
oragex
Post by oragex » Tue Sep 11, 2018 7:23 pm
Also blow some air here or put the vacuum on it, it's the cabin temp sensor and may get covered with dust & stuff - don't touch it physically
drewmeister2
Has thanked: 0
Been thanked: 0
drewmeister2
Post by drewmeister2 » Wed Sep 12, 2018 9:22 am
Yes, I've done that too, and it didn't help.
oragex
Canada
oragex
Post by oragex » Wed Sep 12, 2018 12:50 pm
I would think blower regulator. Push the dealer for warranty before it's too late. It's a $1200 job. It won't give codes, but it's a very well known issue. Soon it will die and you will have no choice to replace it. Maybe try another dealer if not too far away.
