What kind of sealant for the cam cover?
- Been thanked: 4068 times
Those are great, pr...unless you have cats
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Cats don't chew or scratch through plastic?
Cars I've owned:
- prwood
Obvious solution is a separate, locked HF ammo box for each set of bolts removed:
Cars I've owned:
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
They are 8mm hex heads.
All good advice, thanks. I use bags with a marker, and old peanut butter tubs with lids. I have a stack of them, mark on the lids. Use them to soak bolts in degreaser.
These two bolts were alone and unmarked - my mistake. Couldn't put them back in the holes because the cam cover wouldn't go back on with them in the way.
My cam position sensor has these little torx head bolts on the intake side...
Same as the ones holding misc pipes onto the intake manifold. Different size from the sprocket bolt.
- BlackBart
Put those two little buggers back into the cam sprockets - no movement, whew!
Buttoned her back up. Need a sea trials trip somewhere, look for leaks, listen for funny noises. We're thinking of taking Betty to Denver for a wedding next week (1800 mi round trip). Which makes me nervous...
- 9 Replies
- 3159 Views
Last post by MadeInJapan
- 2788 Views
Last post by BlackBart
- 1112 Views
- 1578 Views
Last post by Chili58
- 2252 Views
Last post by smacknab
