V70 Cranks over no Start Topic is solved
MBurt
Year and Model: 2000 V70 XC
Post by MBurt »
2000 Volvo V70 XC
Turned off never to start again.
Motor turns over, tries to fire initially then just cranks. I thought fuel issue so I replaced fuel pump and filter. No change. So checked for spark, spark is good. I replaced spark plugs since it was apart anyways. There is a negative pulse on injectors. 40ish psi on the fuel rail checked with a tire gauge. So diving deeper. I pulled fuel rail and injectors. Here's where I'm lost. Turning the car over with fuel rail loose injectors facing up spraying in the air. For the first couple cranks I get good spray then nothing. I pushed the schrader valve while cranking, fuel flows great even when injector stop spraying. I just got a code reader. Codes P1237 And P0442 I think P0442 was from a line I had inadvertently bumped off the intake tube while trying to get the tube off the top of the motor. Cleared codes still nothing. Tried the lawn mower trick. Checking compression tonight. Where to look next????
MBurt
Post by MBurt »
Got another code reader volvo oem enhanced this one says 91A7, 91B7 Throttle position
Compression test.. 165, 150, 150, 130, 160
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Cylinder 4 has low compression. But that shouldn't prevent starting. Have you tried jumping the fuel pump relay?
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Has thanked: 1611 times
Been thanked: 4072 times
40psi well under spec of 50 psi
Give it a shot of starter fluid yo see if you get some fire in the hole.
This will separate ignition from fuel problem.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Air, probably the MAF.
MBurt
Post by MBurt »
No change using starting fluid. Un plugged the MAF still nothing. I cleared all the codes with the new scanner. The 91A7, 91B7 Throttle position codes came back. Also when watching the real time data on the scanner the tps values aren't changing when pressing the pedal. I'm thinking it might be stuck closed. FUEL SPARK AIR Here are some videos
[youtube][/youtube][youtube][/youtube]
When I turned it over with the injectors removed it almost started.
[youtube][/youtube]
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Are you sure this isn’t an anti-theft issue?
Sounds kinda like the system doesn’t see
your ignition key chip.
Yep. If you don't get fire with starter fluid, it isn't igniting. And if it fires and stumbles for a second or two, then won't fire again, thats ME7 immobilizer behavior.
MBurt
Post by MBurt »
Is there a way to test or bypass the immobilizer system? I only have two keys and neither one of them start it.
MBurt
Post by MBurt »
I was still stuck on the TPS not reading. So I pulled the boot off of the throttle body and watched the butterflies while the gas pedal was pressed, they did not move. I reached up inside and pushed on the butterfly after a little resistance it started to move freely. I kind of mocked everything back together it started and runs. Guess I'll be pulling off the throttle body and doing some major cleaning.
