Cam cover removal
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
I had to use some washers under the cam lock bolts so they wouldn't bottom in the holes. Also, if that center allen bolt on the tool isn't snug, the cams can rotate relative to each other. That keeps them in line.
Cupojoe710
- Year and Model: 2002 S60
Cupojoe710
Also, once I have the lock tool in place, how do I remove the cam cover? It's on there pretty good lol
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
The black plug is a metal-plastic “blank” that covers the rear of a camshaft that doesn’t have a camshaft position sensor (no VVT hub on the other end). To remove it you pierce it with a screwdriver and pry it off. It’s not meant to be reused so you’ll have to buy another one. They’re only $3 or so.
Cars I've owned:
- prwood
This part is fairly detailed, so you’ll want to refer to BlackBart’s or my threads about our cam cover sealing jobs. I’m mobile right now so I can’t find them but may be able to hop back on later.Cupojoe710 wrote: 17 Sep 2018, 17:58 Also, once I have the lock tool in place, how do I remove the cam cover? It's on there pretty good lol
Basically, after the cams are locked, there are 40+ bolts on top of the cam cover that need to be removed. Then there are a few pry points around the edges where you can lever a 3/8” extension bar to pry it off. It can be stuck pretty tight with the existing sealant.
Cars I've owned:
Cupojoe710
I got through it with a little screwdriver, but I've been trying to pry it off for several minutes now lol also the screwdiver I was using to pry now has engine oil on it. I'm assuming I need a new cam seal.
- BlackBart
No, that's normally got oil inside I think. Mine doesn't have that, but all videos Ive seen show oil dribbling out. I think you should always do new seals unless they've been changed recently.
Bigger screwdriver, give it a yank!
Cupojoe710
I appreciate the advice! This is a crazy engine to work on.
- BlackBart
Try this link - go to steps #56 & 57 for the pry points and bolt order. A 3/8 extension does fit pretty well between the tabs built in to the cover. A few taps with a dead blow hammer here and there. Then lift it straight up, not one side or the other.
It's an 850, but the steps are similar.
http://atthetipwebs.com/technologyinstr ... gasket.htm
This is just the timing belt, but this FCP guy is pretty thorough and careful. I don't like all the air gun use, but those guys have to do this fast.
Good PCV system steps here...
- Has thanked: 1614 times
- Been thanked: 4078 times
Oil behind the cam cover plug is normal and drains through a weep hole back into the engine. My volvo dealer had this in stock when I did my Timing belt
Finger tight only on the cam lock tool. Don’t even put a wrench on it.
- 1318 Views
- 1521 Views
Last post by iRenaissanceMan
- 19 Replies
- 5526 Views
- 2082 Views
Last post by wizechatmgr
- 23 Replies
- 2652 Views
