Anyone ever rebuild a brake caliper?
So, I went to replace my rear pads and rotors and found that my left outer caliper piston is seized in place. I can't budge it even with a c-clamp. I'm kinda broke at the moment but was able to get my hands on the seal kit. Does this sound like it might be repairable? I've only ever rebuilt calipers in class on a Buick LeSabre that had probably had its calipers rebuilt 100 time, so I imagine this will be more difficult.
You need to separate the rotorhalves to hone the cylinder as I’m guessing the cylinder is rusty as well as the piston. Piston will need replacing too, most likely. Most rebuild kits don’t be include either the pistons or the orings in between the caliper halves.
It will be a lot faster to get a cheap rebuilt and get a year or two out of it. FCP also warranty’s them for life, too.
That would be ideal, but I've got a road trip I leave for tomorrow. I suppose I can pick one up at work, if my boss will let me take it today and pay for it tomorrow when I get paid. I'm just not crazy about spending extra money for a crappy Cardone rebuilt caliperabscate wrote: 20 Sep 2018, 05:08 You need to separate the rotorhalves to hone the cylinder as I’m guessing the cylinder is rusty as well as the piston. Piston will need replacing too, most likely. Most rebuild kits don’t be include either the pistons or the orings in between the caliper halves.
They run 60 - 90 -180 80 and 180 bucks at FCP for crap, better crap, and OEM Volvo
(updated availability above)
If you don't want to be doing it forever, go Volvo.
Rear calipers are side specific and are used from 1994-2000 according to FCP, so any PnP P80 should work for parts. I would GUESS that the pistons are the same on the calipers but when we assume, we .....
You can also put the seized one back on and drive it gingerly so that the rear brakes never engage, and you won't wear down the pads any more. In NJ, that means 70 in the slow lane.
75 in the slow lane...
- Been thanked: 504 times
I have some odds and ends (brake hoses, lugs etc.etc.)...I can send them to you for free (I no longer have the 1998 S70).
Search for the brake seal rebuild I wrote a while back. Reseal kit is available and you can rebuild in situ.
viewtopic.php?t=37721
Rebuilt Cardone is so so.
If you want a caliper piston, go to local junk yard and pull a good piston. Then buy the FTE Rear seal rebuild kit for $25 at FCPEuro.
Do NOT try to undo the pipe to rear caliper connection, chances are it is seized! Rebuild in situ. This is the approach that gives you the least headache.
Dimensions of internal caliper orings
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Junkyard. NJ has a few.
Other than that, prevention is best. Replace the fluid ever few years.
- 524 Views
Last post by JimBee
- 1339 Views
Last post by ForestVolvo
- 9 Replies
- 2406 Views
Last post by XC70Rider
- 15 Replies
- 6460 Views
Last post by wizechatmgr
- 827 Views
Last post by doublebug
