V70r M66 Engine out the top or bottom?
pdr1966sc
Year and Model: 2006 V70R
Post by pdr1966sc »
I have been searching around and found lots of good resources to prepare for an engine swap in an 07 V70r M66 car.
There seems to be no CLEAR better way, and 'better' maybe be more to do with ones experience and available equipment than anything.
I have a DRIVE on hoist, so my PREFERENCE is to take it out the top - even if I remove the head and associated parts 1st
Can someone offer suggestions on the top out method, and if it is REALLY easier to drop below - if so why?
In theory I could sling the top of the car from my hoist posts and lower the platform down to drop it out the bottom but this might be a bit risky and uncoventional.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Usually from above. Don't forget to replace the slave cylinder.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
From top.
BCM (ABS) module will be an obstacle, which you can work around: unbolt BCM, tilt engine slightly, so the belts side is a bit higher.
I did two engines, first one was a bit hard to take out, but once you figure out how to slide it up, it's easy peasy.
pdr1966sc
Post by pdr1966sc »
OK thanks,
Picture- rest of front all taken off for other reasons?
Pete
vtl
Post by vtl »
Yes, I was swapping out chassis that met with rocks and trees in icy forest ;) Every good bit was taken out and put into a reasonably cheap, neglected donor.
pdr1966sc
Post by pdr1966sc »
Can anyone add - does coming out the top differ between Manual and Auto version (clutch/pressure plate may be longer).
Pete
oragex
Post by oragex »
If you don't get all answers, also try on european forums - they have plenty of manual transmissions that fail at the slave, so have to pull the engine
something like this one https://www.volvoforums.org.uk/
vtl
Post by vtl »
I think AW55 is fattier.
