You need to have that code read, as it probably isnt a fault in the ECC module (thanks for calling it that, and not the ECC!) but one of the other components. It could just be the blower itself.CheTanaka wrote: 28 Aug 2018, 10:24 I have the same problem. Do you have an update on your situation?
On my 2010 S80 (3.2 - 2WD) the fan doesn't blow most times. Only at highway speeds will the fan blow, very lightly and occasionally. Heat or AC, fan still won't blow.
I do have a DTC for the ECC module, where is that located to replace?
Air conditioner only (somewhat) works at highway speeds
- 3532 Views
Last post by johnmatthew
- 9 Replies
- 2477 Views
- 1019 Views
Last post by E Showell
- 12 Replies
- 3232 Views
Last post by willysmd
- 1119 Views
