Cleaning Used Turbo
BlackBrick
Year and Model: 1997 850R
Been thanked: 3 times
Post by BlackBrick »
I bought a used 16T turbo with low mileage. It appears to be in great condition - turbines are good and I see no carbon or burnt oil on the inside. The outside has smudges that I am cleaning with carb cleaner. The wastegate flap I have sprayed with PB blaster to make sure it rotates nicely.
As for the turbines, should I just spray brake cleaner (or carb cleaner?) at them as they self-rotate? Should I put anything like oil or pbblaster on their pivots afterwards?
thanks
Has thanked: 1613 times
Been thanked: 4077 times
Can’t hurt it but these things oil them selves pretty well.
Pressure fed for the bearings, crankcase oil blow by for the air side.
BlackBrick
cool. Just wanted to make sure brake fluid wouldn't ruin anything. Will prob use carb cleaner to be safe.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Brake cleaner and brake fluid are two different things! :?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
BlackBrick
oops, I meant brake cleaner. Doh.
