- Junkyard PEM is about $10-$15.
- Ebay PEM is about $45-$50.
Swap a used a known good PEM and see what happens...
2005 XC90 Died on hwy, fuel pump?
Pulled FPS out and it is pretty corroded even at the plug and around the plug is cracked. Bosch 8629164, having hard time finding one that I'm not getting taped for on price. Any way to find aftermarket compatible? Bosch doesn't make this one anymore.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Fcp , Ipd any FPS for turbo XC90 will do https://www.fcpeuro.com/products/volvo- ... 10#fitment
- Has thanked: 1611 times
- Been thanked: 4075 times
Check your PEM part number and see if you can get a spare from a PnP to try
I can loan you my spare for trial if it fits, if you search your part number in the P2 forum you should find the thread on troubleshooting.
Replaced Fuel Pressure Module, car started right up but now check engine light on. Code came up fuel pressure too high at rail. Tested and came up between 85 and 90
- oragex
That's very high... normal sits near 60. Is the module in good exterior condition without corrosion? Connectors are clean?
Do you still have the original pump?
- oragex
Don't think there is adjustment somewhere, but I remember a similar high pressure issue but my memory fails at what was the actual fix. The FPS is pretty much the last unchecked item on the list. These do fail but no idea if it would rise the pressure..
- 3982 Views
Last post by englemancr
- 12 Replies
- 5199 Views
Last post by dosbricks
- 969 Views
Last post by oragex
- 1149 Views
Last post by raykan
- 18 Replies
- 2955 Views
Last post by cn90
