Cruise Control Intermittently working-- stumped
- Has thanked: 1611 times
- Been thanked: 4072 times
Remember if you lose traction , even briefly, cc will shut off. The bump might be causing that
- Has thanked: 311 times
- Been thanked: 818 times
There are zero differences between 95-96-97-98 CC setups.WhatAmIDoing wrote: 30 Sep 2018, 00:29 The vacuum lines are a pretty good bet and cheap to replace. The switches for the clutch and brake are also an easy place to start. I don't know if there is any record of the CC pump or relay ever going bad, but those should be easy to test. Also should check the fuse for CC. Some users have reported the wiring for CC failing in the turn signal lever.
Edit:This is a good guide. Does anyone know if there are difference for CC between a 95-96 and a 98?JimBee wrote: 29 Sep 2018, 20:13 I just found the link you need to troubleshoot all the parts of the cruise system. I'll be using it too. Read down the thread, erik posted the link:
viewtopic.php?f=1&t=65680
(1) Check the rotting vacuum lines, that's usually the problem. Don't forget the hard plastic line to the firewall.
(2) If you're still stumped, realize you should have just used the troubleshooting guide, it is easy to follow and works.
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
I heard it could also be ABS sensor related, some time of speed sensor if I recall properly.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- 1130 Views
Last post by Stoneworks
- 9 Replies
- 5286 Views
Last post by THeOldMan
- 704 Views
Last post by howardc64
- 32 Replies
- 9842 Views
Last post by zhenya
- 720 Views
Last post by Denwiley
