fill reservoir too high, it leaks out of the passenger side headlight wiper
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
If I fill my reservoir too high, it leaks out of the passenger side headlight wiper. Do you know where it's leaking?
Knows enough to be dangerous
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
my reservoir overflows somewhere else when filled all the way up. since it is quite big, i just don't fill it all the way anymore. do you park your car on a steep driveway with the front facing down? if so, your problem is problem might be just that. if the headlight nozzle is lower than the reservoir it will leak.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
voltech1
- Year and Model: 2000 V70R
- Has thanked: 2 times
There is a check valve behind the passenger headlamp that is leaking. You can find the washer hose running between the headlamps. If you gently pull the hose going behind the passenger lamp it should show itself. The valve will need replacement.
96 855 turbo 235k
00' v70r 156k w/blown motor
- 1517 Views
Last post by Tkollars
- 1585 Views
Last post by Clemens
- 923 Views
- 2067 Views
Last post by polskamafia mjl
- 2867 Views
Last post by Archer
