IPD sale Volvo Parts
Did you know? 🤔
URO Trash Strikes Again
ferocity02
Year and Model: 1998 S70 GLT
Has thanked: 0
Been thanked: 6 times
United States of America
ferocity02
Post by ferocity02 » Sun Sep 30, 2018 6:03 pm
When I first got this car it had a really bad oil leak. Turns out the rear cam seal popped out behind the cam sensor. I figured it was likely due to a blocked PCV system so I replaced it all with a URO Parts PCV system.
5.5 years and 20k miles later the car is leaking a bunch of oil from the front of the engine. After lots of cleaning I figured it was coming from the PCV oil trap box area. The lower hose/bushing thing was total mush. The upper hose was also trash. About 3 years ago I had to replace the two 90 degree adapters that connect to the PTC valve. The 90 degree adapter going to the intake manifold disintegrated when removing the manifold.
I replaced it all with genuine Volvo parts. Lesson learned.
These users thanked the author ferocity02 for the post (total 2):
matthew1erikv11
Has thanked: 185 times
Been thanked: 574 times
Trinidad & Tobago
Re: URO Trash Strikes Again
Post by abscate » Sun Sep 30, 2018 6:53 pm
That’s freaking ridiculous. The oil load there is well known and rubber that resists oil isn’t hard to fab.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Has thanked: 6 times
Been thanked: 129 times
Canada
Post by scot850 » Sun Sep 30, 2018 7:47 pm
My URO parts oil short 'J' hose into the front of the block from the oil separator lasted less than 2 weeks and 700km before it split.
Yes their rubber parts are crap and we have had many of us find out the hard way. Good luck with the fix and only OE hoses.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Has thanked: 0
Been thanked: 71 times
Post by cn90 » Sun Sep 30, 2018 7:54 pm
I am surprised you did not read the URO threads from other people.
Their products are inferior, you lose not only money and time.
The only URO part I buy are metal stuff:
- BMW E39 thermostat aluminum housing, even so I have to sand it flat etc. OK now.
- 2004 V70 exhaust metal hanger.
Do not buy URO rubber parts.
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 20 times
Been thanked: 20 times
ecbsykes
Post by ecbsykes » Sun Sep 30, 2018 7:56 pm
Another URO nightmare here.
I had cheaped out and replaced the power steering reservoir-to-pump hose with a URO one. A couple years later, it was so swollen that it finally made contact with the serp belt, got cut, and sprayed fluid all over the place. I had just enough to make it to the dealer and then home. It sucks spending like $70 on a hose, but the original one lasted the better part of 10 years.
2000 V70XC - 281,000 miles
wizechatmgr
Has thanked: 19 times
Been thanked: 47 times
wizechatmgr
Post by wizechatmgr » Mon Oct 01, 2018 1:55 am
Weren't the URO folks on here before touting their reformulations? If it cannot handle oil, it isn't fit for purpose in the automotive world...
1999 V70 XC AWD - ~175k miles
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 343 times
matthew1
Post by matthew1 » Mon Oct 01, 2018 11:48 am
Yes. September 2015.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Year and Model: Lots
Has thanked: 4 times
Been thanked: 93 times
Australia
Post by precopster » Mon Oct 01, 2018 4:45 pm
URO assures us that procedures and materials have been markedly improved since PO's date of manufacture. Let's hope so as I've used some of their parts since then.
The heavy duty spring seats have been used in our XC90 and I think the little PCV bottle to engine block tube as pictured above as well as the connecting pipe and the crankcase breather hose. Its going to take my wife 6-7 years to do 20,000 miles though
I downgraded her XC90's PCV system to the earlier one as the later (larger) parts were too expensive.
15,000km and almost 2 years so far and no leaks.
I've also used the URO fuel door hinges-they work great
The Pro Parts spring seats on my 2001 V70T5 have just begun to crack after about 20,000km (I noticed FCP don't sell these any more)
These users thanked the author precopster for the post:
matthew1
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
