My 1999 s70 n/a has a hard time starting after a fillup, either automatically by the pump, or manually before the tank is full.
Tank is NOT topped off.
Engine will start but must maintain revs 3000+ to run.
Once underway, no problems.
Your thoughts, please.
1999 S70 NA Hard Starting after fill-up
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You are getting raw fuel into intake through carcoal canister.
It could be because of tank ventilation system failure.
If it does that always it would be fuel pressure regulator leaking fuel through vacuum line.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Any codes that are coming up?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 4069 times
No FPR on a 1999 with ME7 - but the overloaded EVAP canister is almost certainly it.
It moved to the rear passenger floor area, just in front of tire, in late 1998
Added year model to title per forum rules
- misha
Not even integrated in fuel pump housing/assembly?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
YEs, fuel pressure is regulated there, but without a vacuum line. It is electronically regulated by feedback from the fuel pressure sensor. I dont think that will cause the symptoms reported here.
- misha
P2 models have the same set up too...at least early ones...2000-2002.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha wrote: 02 Oct 2018, 07:29 P2 models have the same set up too...at least early ones...2000-2002.
I think it is
1992-1998 P80 Vacuum operated FPR - some on fuel rail, some on power steering rack (years/models?)
199-2001 Bastard FPR electronically regulated, fuel pump relay in fusebox, fuel pressure sensor ?
2002-2008 relay on CEM, CEM drives PEM with a signal, PEM drives fuel pump with another signal - fuel pressure measured on rail
kumulipo
- Year and Model: 1999 S70
- Has thanked: 7 times
Thanks for all your help.
Will post codes next time it happens.
I'm remembering P0405. That's not reliable.
So my repair would be the carbon cannister plus associated hosing? Plus checking the fuel rail situation?
Between fillups it starts easily.
Thanks again!
Thanks again!
- misha
You must find the reason why carbon canister is flooding...not replacing it.
Doing that you will not solve nothing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2099 Views
Last post by polskamafia mjl
- 2880 Views
Last post by Archer
- 10 Replies
- 3913 Views
Last post by Blacklab467
- 472 Views
- 19 Replies
- 3015 Views
Last post by z80
