Found this in VIDA. Vehicle profile set to 1996 AME 850.
Information type: Specifications, mechanical.
Search all for "Rear wheel hub" you should find it.
One thing Volvo is infamous for is: midyear production changes that are not uniform across the production plants.
Jim Bee: What is the thread size of the shaft end?
New nut for rear wheel hub
A new nut for the rear wheel hub will be introduced into production on all 850 models.
Factory Code: Model: Chassis No:
1 854 1219646
1 854 2221178
2 855 2121509
The introduction of the new wheel hub will result in the following changes:
The shaft end thread size has been increased from 20 mm to 22 mm.
New, self-locking nut with 22 mm thread.
The new nut is re-usable.
Note! The rear wheel hub threads must be oiled before reinstalling the nut.
Tightening torque for the new nut is 120 Nm (89 ft.lbs) + 35°.
1996 850 rear hub torque, 3546510 9200250 change mid year in 1996 Topic is solved
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
- RickHaleParker
Abscate: 1999 P80s? ... '97 was the last year for the 850.
Active
Past
Past
- Been thanked: 4068 times
I think the P80 designation was used up to 2000 for the V70 chassis and 2005 for the C70
I missed your post above, Rick, it got caught in the electronic binder as I turned the thread page....
I’m happy that my intuition on reusing the nut was good!
If anyone comes across the part numbers for the two nuts
20mm thread , 120 Nm plus 120 angle
22 mm thread. 120 Nm plus 35 angle, oiled threads
- RickHaleParker
20mm - 3546510.
22mm - 9200250
Always check the size, The Axle may of been upgraded.
22mm - 9200250
Active
Past
Past
Thanks Rick, added part numbers to title for search
I am going to check on something this morning.
The rear nut may be one of these Volvo self locking with a metal shoulder inside the thread, in which case my re-using it is a really, really bad idea.
The inspiration for this was that I came across this with the P8- ball joint retaining bolt/nut. Its not really high torque but the nut has a soft metal shoulder that locks it in place.
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
What's your source for the 1999- torque value of 30 Nm? Haynes says 120 degrees plus an angle, but they don't always differentiate between -1998 and 1999-. I tried to search VIDA for "rear wheel hub" with profile set to 2000 V70 AME but I got only partial information, as if my VIDA is incomplete.abscate wrote: 09 Oct 2018, 04:48 It looks like they backed the torque off in 99
A change in angle torque from 120 degrees ( early) to 30 (1999) is a huge change in final torque
The nut doesn’t see any rotational force, it just pins the hub to the shoulder on the spindle.
Confessions..when I did my rear hub I re-used the nut as I calculated the deformation was near zero, well below the plastic limit
I'm basically wondering if I can reuse nut 9200250 on a 2000 V70 because it's at low torque or must replace it because it's at high torque. Hate to spend another $20 to replace my rusted brake dust shields.
FireFox31
The torque spec is
120 Nm , then 35 degree angle
Per ricks post above from VIDA. The change came about 1996 with a change in axle shaft diameter
1 854 1219646
1 854 2221178
2 855 2121509
- 2074 Views
Last post by oragex
- 1200 Views
Last post by wizechatmgr
- 2419 Views
Last post by [email protected]
- 6019 Views
- 1925 Views
