Volvo 98 S70 Dipstick Tube replacement and tools required
TreeFort
Year and Model: 98 S70 Turbo
Post by TreeFort »
What tools do I need and how do I both remove and reinstall the Dipstick Tube? Not familiar with this stuff so the more details the better. Thank you for your help!
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Hello, welcome to MVS!
If I remember correctly, you just use a 10 or 12mm socket on the bolt near the top of the dipstick (that holds it in place). Once that's out, the whole thing should pop out of the oil pan with a small tug.
You replacing the o-ring or something down there?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
TreeFort
Post by TreeFort »
No I just have to replace the tube because the new dipstick I had to order doesn’t fit in the old one, and therefore doesn’t pass smog check.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Good old Cali emissions...
Yeah, believe there is an o-ring at the bottom and a bolt at the top under or near the intake manifold - almost identical to the V70 except possibly the part number and fitment.
TreeFort
Post by TreeFort »
So it sounds like it shouldn’t take more than 10 minutes?
wizechatmgr
TreeFort wrote: 12 Oct 2018, 19:51 So it sounds like it shouldn’t take more than 10 minutes?
Yes, including washing your hands afterwards. =)
TreeFort
Post by TreeFort »
Hahaa! Ok, rad. Thanks!
FlyingVolvo
Very quick replacement. Hopefully new tube comes with an o-ring. If it doesn't you might want to consider replacing it as they get old and can leak.
2023 V60 T8 PE
TreeFort
Post by TreeFort »
It does not. Can I pick one up at a hardware store?
FlyingVolvo
If you can find an exact fit, sure. If not, clean up and re-use the old one if it's still in one piece. Next time you order something from one of the online parts stores you could get a new one cheap. Less than a dollar for aftermarket, a few bucks for Genuine.
2023 V60 T8 PE
