Be carefull on oil dipsticks because there are two versions depending on crankcase capacity.
One is red and the other one is fluorescent.
Difference is in about 1liter of oil.
Red...between min and max 1l of oil is needed.
Fluorescent...between min & max 1.5l of oil needed.
Dipstick tubes are also not interchangeable between those two dipstick colours.
Volvo 98 S70 Dipstick Tube replacement and tools required
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Nothing takes 10 minutes to do, basically. The bolt is a little tricky to get to IIRC, and you need a few angled tools to facilitate removal. Be careful not to cross thread when installing. Clean it up well. Don't do it before you have to pick up your kids or rush anywhere, though pretty easy like everything takes a few. Seat the dipstick tube well before tightening down, use a little lube or grease to facilitate. Watch for leaks after!
- Has thanked: 311 times
- Been thanked: 817 times
+12,337,987
My favorite are the posts titled "DIY Fix problem x for only 15 minutes and $4.37!!!" where you need $80 in tools (and that's Harbor Freight rates) just to get started.
In 10 minutes you can walk out the back door, open the garage, pull the car in and open up the tool box.
- 5019 Views
Last post by JimBee
- 1815 Views
Last post by chaos26670
- 2739 Views
Last post by matthew1
- 9 Replies
- 4065 Views
Last post by PapaNoni
- 896 Views
Last post by Bandit123
