Where did you get the idea that you will undo wheel bolts with a ratchet?
Do you have specialised crossed key for wheel bolts?
Even with it you will need a breaker bar to undo them.
Diary of a 17 y/o with an 850
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Looks like a 1/2" breaker bar that had a 1/2" to 3/8" adapter on it. Better off with black iron (impact) sockets for dealing with wheel lugs whenever possible.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Make sure to check if the rear brake calipers aren´t seized. They have a tendency to do that with age. Not really a bad job and totally worth it.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- shihabafi
- Year and Model: 1995 850 Wagon
- Has thanked: 50 times
- Been thanked: 8 times
Changed the left rear brake caliper some time ago, and saw that the right one was pretty good.Clemens wrote: 15 Oct 2018, 02:14 Make sure to check if the rear brake calipers aren´t seized. They have a tendency to do that with age. Not really a bad job and totally worth it.
It was the breaker bar from Harbor Freight. I don't have the crossed key...misha wrote: 14 Oct 2018, 16:27 Where did you get the idea that you will undo wheel bolts with a ratchet?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Breaker bar, 1/2"-drive socket with a short 1/2"-drive extension.
Not surprised you twisted off an adapter like that. The lug bolts get pretty stubborn on these.
- Been thanked: 4067 times
If you use lubricant and back off the torque to 50-60 ft lbs instead of the stock 80 ft lb, it is much easier on your tools and your back - which will thank you later in life.
Quick review of the engineering on this
Dry torque spec is 80 Ft lbs
Torque is roughly three components, roughly equal in contribution.
Head friction
Fastener Plasticity
Thread friction
If you lube threads you reduce the thread friction and head friction, so I use 25% torque reduction as a SWAG on all my cars.
This also means the 6/7 ladies in my house can remove lugnuts with factory tools.
the 7th one can remove 80 ft lb nuts with her fingers, as the Frat boys found out.
Head friction
Fastener Plasticity
Thread friction
- Has thanked: 2857 times
- Been thanked: 1332 times
That shifter... you know when you read news stories from Montana or wherever when a bear gets into a car and can't get out, and it thrashes the interior? That's what I thought of when I saw your old shifter!
- misha
If he want to chase wheels down the road.abscate wrote: 15 Oct 2018, 09:18 If you use lubricant and back off the torque to 50-60 ft lbs instead of the stock 80 ft lb, it is much easier on your tools and your back - which will thank you later in life...
Seriously....it's not fun when your wheel bolts get loosened while driving.
It happened to me 2 times right from tyre shop....from that time i always re-torque them myself with crossed wheel lug's tool and never had the problem again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- shihabafi
If you'd like it as a gift I can send it over!matthew1 wrote: 15 Oct 2018, 09:40 That shifter... you know when you read news stories from Montana or wherever when a bear gets into a car and can't get out, and it thrashes the interior? That's what I thought of when I saw your old shifter!
So me and my friend took off the front wheels with the intention of throwing on new pads to get rid of the squeaking, and resurface the rotors, but we were met with a surprise to find out that the brakes still had about 50% of their meat on them...
SO... If the squeaking isn't coming from the brakes... Where else is it coming from?
It's a soft squeak, it appears around ~15mph and disappears by 25. Any ideas?
Also, Why is there thick and heavy oil-y gunk on the end of my wheel bolts?
- misha
It's a grease.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 46 Replies
- 8018 Views
- 9 Replies
- 5056 Views
Last post by vtl
- 4712 Views
Last post by tryingbe
- 676 Views
Last post by shaker_chi
- 886 Views
Last post by misha
