All Gauges out, and digital Outside Temp, Gas info, etc Out as well
bradmball73
- Year and Model: 1999 C70 Coupe
My speedometer went out and the ABS lights came one. I replaced the ABS module. The lights for ABS light went out, and speedometer still didn't work. Then, I replaced the battery, and battery positive terminal connector (where wire connects, Not the actual clamp that connects to the battery) and now of my gauges and none of the digital information for the Outside temp, MPG info, etc is working either. From what I read online, the actual instrument cluster do usually not go in these cars. Please help
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 311 times
- Been thanked: 817 times
Electrical portion of the ignition switch. Try jiggling the key, see if that exacerbates symptoms.
bradmball73
I replaced the ignition switch with a brand new one and that did not fix anything. Any other ideas???
- misha
- Has thanked: 155 times
- Been thanked: 432 times
1st...remove negative battery cable for about 15min and re-connect.
2.Check ALL fuses
There is a BIG possibility that you fried something when you worked on positive side of the battery IF you didn't remove battery cables first.
I hope that you didn't mixed connections....+ On - and - on +.
2.Check ALL fuses
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2199 times
Did you check the condition of the B+ cable at the battery and more importantly at the main fuse box? Check it carefully at the fusebox end. It attaches via a brass nut at the front of the box forward of the brake booster. The nut should be shiny. Shine a flashlight downward at that point and check to see the cable has not melted as it will short out.
Do you have any codes being thrown?
bradmball73
Just the negative...therefore leaving positive connected to battery?misha wrote: 19 Oct 2018, 02:15 1st...remove negative battery cable for about 15min and re-connect.
2.Check ALL fuses
- misha
What "just negative"?
Negative was disconnected while you worked on positive terminal?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Yes. Just the negative, for 15 minutes.bradmball73 wrote: 19 Oct 2018, 09:08Just the negative...therefore leaving positive connected to battery?misha wrote: 19 Oct 2018, 02:15 1st...remove negative battery cable for about 15min and re-connect.
2.Check ALL fuses
- misha
Remove the key from the ignition lock...just to make sure that ignition IS NOT ON while disconnecting & re-connecting negative battery terminal...wait for 1-2 minutes allowing instrument cluster to settle and check if it's working.
Meanwhile....check for ALL fuses and that positive terminal for poor connection...since all of this happened when you replaced it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 514 Views
Last post by callahanoffroad
- 159 Views
Last post by misha
- 557 Views
Last post by darrylrobert
- 1710 Views
Last post by yagger
- 1347 Views
Last post by FLXC90
