Hello, I'm trying to diagnose my not starting issuenof my 97 850NA and I'm down to my immobilizer relay. I am new to using a Multimeter. Could someone explain what terminals I should be probing and possibly what ohm readings I should see?
Thank you.
Dustin
Testing 210 Relay with multimeter
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
- Year and Model: Lots
- Been thanked: 128 times
I would say that the green connector has the coils which should have around 5 ohms across them.
That only gives an indication of coil failure which is extremely rare.
The most common type of failure in relays is burned out points so you'll need to open the case with some fine jeweler screwdrivers by prying on the case at as many points as you can while pulling the grey cover off the base. You'll see some polished contacts inside with a gap between them. They are the points and are usually pitted and burned.
- Been thanked: 4068 times
You should just get a pick and pull one for 3 bucks And swap to diagnose. Check classifieds here too
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
This information may not help with your specific relay, but often the pins are labeled with 15, 30, 31, 87, 87a. I think in your picture it's possible to read 15 and 30 on a couple of the pins.
From what I've gathered, the these numbers are part of a DIN specification. To decode the numbers, you can look them up (for example, http://www.bosch-classic.com/media/en/b ... nungen.pdf )
15 = Switched positive after battery (ignition-switch output)
30 = Line from battery positive terminal (direct)
31 = Ground
87 = Input
87a = Output
31 = Ground
87 = Input
87a = Output
- BlackThunder
Ok, thank you. I'll test it today and probably take it apart and re flow joints as needed. I'm trying to get to the bottom of my problem.
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I had never seen that relay go bad.
The problem might lay in the immobiliser box(black box and it says Volvo immobiliser on it).
It's under the steering wheel panel .
But again....U.S market didn't had chipped keys until '98,so you shouldn't have immo ecu.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
That’s the “Guard Alarm” security module.
There’s a lot more going on in there than
just relays. And IIRC, the three pin green
connector is the input from the key fob
receiver over on the passenger side kick.
I think 210/211 module ia also where the
code from the fob lives, so if you replace it,
you’ll probably have to reprogram your fob
code into it.
code into it.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Finally, after a year, I found this very informative thread again of how to disable the immobilizer of the 210/211 relay and still keep the keyless entry.
http://www.forums.turbobricks.com/showt ... p?t=238812
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
I don't want to bring bad news...but U.S market immobiliser system is totally different from EU market.
If you have chipped key in '96 this will not work.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Yeah, true, but remember this is about the FOB immobilizer which sits in relay 210/211 additionally to the chipped key.
Some day i locked my car with the remote and then it wouldn't unlock with the remote. Opening the door by key only triggered the alarm and I had to remove relay 210/211 and bridge 50e and 50? with a paper clip to drive home.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1057 Views
- 544 Views
Last post by Randomnamegenerator
- 9 Replies
- 7346 Views
Last post by Jeff Schubert
- 2560 Views
Last post by IslandV70
- 508 Views
Last post by loveMy850
