Testing 210 Relay with multimeter
BlackThunder
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 3 times
Post by BlackThunder »
Hello, I'm trying to diagnose my not starting issuenof my 97 850NA and I'm down to my immobilizer relay. I am new to using a Multimeter. Could someone explain what terminals I should be probing and possibly what ohm readings I should see?
Thank you.
Dustin
Bottom of Relay 210 211
Relay
Relay
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I would say that the green connector has the coils which should have around 5 ohms across them.
That only gives an indication of coil failure which is extremely rare.
The most common type of failure in relays is burned out points so you'll need to open the case with some fine jeweler screwdrivers by prying on the case at as many points as you can while pulling the grey cover off the base. You'll see some polished contacts inside with a gap between them. They are the points and are usually pitted and burned.
Been thanked: 4071 times
You should just get a pick and pull one for 3 bucks And swap to diagnose. Check classifieds here too
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
This information may not help with your specific relay, but often the pins are labeled with 15, 30, 31, 87, 87a. I think in your picture it's possible to read 15 and 30 on a couple of the pins.
From what I've gathered, the these numbers are part of a DIN specification. To decode the numbers, you can look them up (for example, http://www.bosch-classic.com/media/en/b ... nungen.pdf )
15 = Switched positive after battery (ignition-switch output)
30 = Line from battery positive terminal (direct)
31 = Ground
87 = Input
87a = Output
BlackThunder
Ok, thank you. I'll test it today and probably take it apart and re flow joints as needed. I'm trying to get to the bottom of my problem.
Dustin
Dustin
2013 Volvo C30 T5
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I had never seen that relay go bad.
The problem might lay in the immobiliser box(black box and it says Volvo immobiliser on it).
It's under the steering wheel panel .
But again....U.S market didn't had chipped keys until '98,so you shouldn't have immo ecu.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
That’s the “Guard Alarm” security module.
There’s a lot more going on in there than
just relays. And IIRC, the three pin green
connector is the input from the key fob
receiver over on the passenger side kick.
I think 210/211 module ia also where the
code from the fob lives, so if you replace it,
you’ll probably have to reprogram your fob
code into it.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Finally, after a year, I found this very informative thread again of how to disable the immobilizer of the 210/211 relay and still keep the keyless entry.
http://www.forums.turbobricks.com/showt ... p?t=238812
1996 855 R,
2010 V70 D5,
misha
Post by misha »
I don't want to bring bad news...but U.S market immobiliser system is totally different from EU market.
If you have chipped key in '96 this will not work.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Post by Clemens »
Yeah, true, but remember this is about the FOB immobilizer which sits in relay 210/211 additionally to the chipped key.
Some day i locked my car with the remote and then it wouldn't unlock with the remote. Opening the door by key only triggered the alarm and I had to remove relay 210/211 and bridge 50e and 50? with a paper clip to drive home.
1996 855 R,
2010 V70 D5,
