1999 S70 MCC AC/Heat Unit head. 3524842
beav700
Year and Model: 1999
Post by beav700 »
Hi guys. I'm new here. Buying a 99 s70 tomorrow for $500. Got 180k miles. Needs a lot of work but in mint cond. Even seats look new cause everything was covered and garaged. One thing that is busted on the inside is AC Heat control unit. I went to 4 junk yards and all had them in 98-2000 volvos but the units had sliding fan speed control. Ebay sells dozens of the same (sliding) with 4 buttons. Mine has round knob with 2 buttons. For the life of me I can not find a matching part. I've looked at hundreds of pictures, all show sliding unit. What am I missing here. Picture attached. Mine is on the right side.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
The one on the left is ECC (electronic climate control) and the right is MCC (manual). The manual one is cable operated, and comes in the base models. They aren't too common, which is why you aren't seeing many (if any) of them.
If you're searching on eBay, try to add "MCC" or "manual climate control" to your search. Someone on this site may even have one for you. Unfortunately I don't have on sitting on the shelf currently.
beav700
Post by beav700 »
Thanks for the help. Sure enough, it's MCC unit. Even Robert has videos about it. Now I have to find one.
beav700
Post by beav700 »
Found one on Ebay for $315. That's crazy. ECC unit sells for $20, the MCC is $315.
Has thanked: 1611 times
Been thanked: 4075 times
Demand and supply. Raw capitalism.
You should be able to find this using the part number
beav700
Post by beav700 »
I just visited 2 more junk yards. One had close to dozen 99-00 Volvos. Every unit was ECC. Never ran into a Volvo that was different than 99% of all other Volvos.
bmdubya1198
Ouch, that's steep for a climate control unit. You don't always think that the lower end, base model option is the more expensive one later on!
beav700
Post by beav700 »
I know. And this base model V70 is loaded. leather everything, power everything, heated seats, sunroof. Someone ordered the base model with everything as option.
Part number 9171600
The MCC control unit is available new for about $125 if you search
bmdubya1198
abscate wrote: 28 Oct 2018, 07:36 Part number 9171600
One of the few parts like that that make sense to buy new! I'd do this if you can't find a cheaper one used.
