07 V70 Horn does not work
cliffordhubbard
Year and Model: V 70 wagen 2007
Post by cliffordhubbard »
Looking for horn relay and fuse. See on some places fuse panel on driver side of dash has a 15 amp. According to diagram on fuse door, not there. Help?
Thanks
Cliff
Has thanked: 1505 times
Been thanked: 3818 times
Cliff...owners manuals are free online from Volvo. Probably the best place to start.
https://volvo.custhelp.com/app/manuals/ ... /om_id/448
cliffordhubbard
Found 15 A fuse. Replaced. Horn now work. Any thoughts on why it blew? Where to look?
Thanks
Cliff
Give it a few cycles and tries - fuses do age and just go, without other faults
cliffordhubbard
Fingers crossed. Daughter takes her drivers test Friday. Have to make sure everything is in order.
cliffordhubbard
Horn not working again. Only honked a couple times. Thoughts? Thanks Cliff
cliffordhubbard
Ok how about where is horn relay? Thanks
Cliff
I think your 2007 is the same as my 2005
Horn power comes from the CEM, terminal B15
The relay is bonded into the CEM, I believe
The CEM triggers it when it receives the signal from the SWM that the horn button is depressed.
cliffordhubbard
so the CEM needs to be replaced? Spoke to a retired volvo mechanic this afternoon. he seems to think the relay is on fuse panel beneath right dashboard...
Go to the web and look for the 2007 wire diagram
The big “fuse box” on the driver side is the CEM. You can’t just replace that it has to be matched to the car by a firm like Xmodex
