So at the end it all comes to quality of outsourced components. Which is hard to bullet proof, because it takes years of field testing to make sure the quality is at the level. And after those years no one will be wanting to buy ancient 5-speed gearbox, because every other new vehicle comes with 8-speed already. So all you can do is to pray that your suppliers have similar view on what quality is.
Subaru had good AWD when it was mandatory to rotate tires every 5k miles (or did they call for 5k kms?). These days "civil", non-STI Subaru's have alike quality/principle of operation in AWD system.
Auto trans.
Buyers Advice P2 vs P3
- Has thanked: 2856 times
- Been thanked: 1332 times
Notice: This is a new post on an old thread. Fast forward two years and...
Anyone have any updated thoughts on P2 vs. P3? Are you more or less likely to move to a P3 Volvo? If you're in a P3 Volvo, how do you like it?
P3
S80 2007 - 2016
V70 2008 - 2016
XC70 2008 - 2016
XC60 2010 - 2017
S60 2011 - 2018
V60 2014 - 2018
P3
S80 2007 - 2016
V70 2008 - 2016
XC70 2008 - 2016
XC60 2010 - 2017
S60 2011 - 2018
V60 2014 - 2018
MacNoob
- Year and Model: 2007 XC70
- Has thanked: 2 times
A P3 V60 or S60 (2014+, with 2.5 I5) will likely be my next car once the current P2 XC70 is inevitably taken out by either wildlife or one of the inexperienced new drivers in my area (already lost wife's car in a parking lot to one of those).
Just keeping an eye on which might have oil consumption issues.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Our then new 2016 XC60 was rusty from day 1. Look underneath: both subframes chip and rust, especially at welded joints (oh yeah, Ford forced Volvo to used cheap steel for subframe). Belly is also prone to quick rust when enormous amount of Noxudol wears out. Our P2s didn't even have any Noxudol out of assembly line.
Also its paint maybe 1/3 of what my 05 XC70 has. And somehow it feels cheaper inside, though we paid for the Platinum trim. I don't know... When I crashed my car about 1.5 years ago, I opted to buy a donor and swap everything undamaged from my car. Lot of labour, but still better than driving a new Volvo.
vtl
When it was couple of months old:
Our P2 V70 and 2 XC70 didn't/don't have any chips like that:
Now:
Yeah baby, this is body rust! Unheard on P2!
In winter all the water freezes (apparently!), but the cheap plastic used in P3 does not flex enough, so we have a broken driver side mirror (wobbles a bit), front bumper off the alignment. The rear doors freeze to the body, every cold morning after ф rainy day I pour a gallon of warm water over the door seals.
Also the rear door wiper motor died, dealer had to replace it. While replacing, the tech damaged plastic gear inside it, so the wiper wobbles. Transmission was engaging horribly from day one, software update that was applied after about 1.5 years did "fix" it, however the car is lazy dog now. Also when I drain&filled ATF after 2 years of use it was brown, with a lot of chunks from friction plates - not those tiny black spots from normal wear, but literally chunks broken off. I also found sealant chunks in motor oil when the factory fill was replaced, who knows what tight passages are semi-blocked?.. The car was loosing the brakes semi-randomly after like 4 months of use, two dealers could not diagnose that. I did a video how I, customer, flush the brakes on the new car and it has bubbles in it, have sent it to Volvo. They sent a field tech to look at it, he said: "I don't know what's wrong with it, let's replace the master brake cylinder". Thanks, it helped. Only after a few months of fear on the roads.
I gave up on that car, won't take care and repair as I do with XC70. For long family trips we take XC70, which is ole good Swedish metal and simply more comfortable (oh, yeah, XC60 drives and handles like a Russian UAZ!).
Now:
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Techs don't like P3 models. They have longer brake life (not rears always) and far less maintenance items. The suspension work they can always find to do on P2 is not there on P3 even with well over 100K miles.
The rear wiper gears are inside motor and not touched nor serviceable. Look at wiper arm angle and the angle it makes in blade on glass. The arm can be twisted in removal and will make blade dance on glass if arm and thus blade is twisted.
- 1913 Views
Last post by rerobin66
- 1591 Views
Last post by precopster
- 1204 Views
Last post by MadeInJapan
- 1416 Views
- 424 Views
Last post by vtl
