No rear fog light on 1998 V70 R AWD. Topic is solved
Has thanked: 1497 times
Been thanked: 3809 times
Re: No rear fog light on 1998 V70 R AWD.
If you don’t have 12 volts at the lamp bulb, you trace backwards until you find the 12 Volts.
One weak spot on these cars is the wiring harness in the left tailgate in North America, I’m not sure if it’s wired the same side in UK but it is worth exploring
Pentacyl
Year and Model: 1998 V70 R AWD
Has thanked: 14 times
Post by Pentacyl »
Hallo and thank you, abscate!
There's zero volts at either side's fog lamp. Have I said all other lamps are good?
The UK version's wiring harness also runs along the LHS. I've had the rear seats/boards/carpets out, unclipped the ducting and the violet/white lead is intact. I've not got any further as had to use car. We have guests visiting this week so nothing much will happen before next weekend.
Nothing much that is until the new switch arrives... Fingers crossed!
Pentacyl
Post by Pentacyl »
Good news!
New switch sent power down the violet/white line. Whilst there was power at the back of the car, the rear fogs were still not working!
I did continuity checks on both left and right lampholders and found a break between the violet/white power pin and the fog lamp connector, in both lampholders. I traced this to a broken/removed, zinc strip. Holding the lampholder lampside up, with the fog/tail light housing at the bottom, there are two, ±2mm, grooves in the black pastic, ±30mm apart, slightly above the housing and to the left. The missing link ran between the two zinc strips, immediately adjacent to the right of the grooves.
I remade the link and bingo, the rear fogs became fully operational. If anyone wants photos, PM me and I'll be happy to do the necessary.
Thank you to all contributors. Your help is very much appreciated.
Great! you can send me the pics and Ill attach to the thread - since you guys are Brexiting we don't allow UK pictures anymore without a 25% tariff on MVS membership fee.
(seriously, its nice to put them in the thread for reference)
Pentacyl
Post by Pentacyl »
Ha-ha-ha! JHC, I thought that Brexit is meant to strengthen USA/UK bonds. Maybe that's "false news"...!
Case in point, we've friends over from France - last visit before the tunnel is flooded? - so will send snaps at end of week. Do I do that via PM?
Also, Matthew sent me a PM but I couldn't answer. Is there a work-around to the restriction, please?
Pentacyl
Post by Pentacyl »
I've not done the snaps but HAVE bought a VIDA manual and found the reason/easy explanation to the mysteries of the rear fog light. There are two, lower tail light lamp holders available!
Whether or not there is a rear fog light, is down to which lamp holder is fitted. The two types are, #3512418 w/rear fog light circuit and #3512419 w/o rear fog light circuit! They fit equally either left or right hand side.
Hope this helps.
You’ve passed the 10 post initiation marker so you should be able to attach pics.
Hit the Full Editor button
Click attachments tab
Add files button
Choose file ( it helps if you have made it easy to find or on desktop)..include your favorite dog
Wait for it to load
Submit button
Pentacyl
Post by Pentacyl »
Thank you, excellent, good to know. I'll try to get to the photos tomorrow.
