That oil leak finally caught up with me today and I blew one of the major seals on the front of the engine while in town today. Was losing somewhere in the ballpark of a quart a mile. Got home after stocking up on oil at the store next to me but was still not a fun trip. Assuming it's the main crank and not one of the cams, how atrocious a job is it to replace it yourself if you don't want to drop the engine? I ask because the nearest dealer is several hundred dollars in towing away and I can't pony up that kind of cash right now for the towing alone.
In addition to that, I'm definitely going to replace the belts and PCV box (wasn't plugged when I checked last but that was 6 months ago annnnnd now I'm not so sure).
In terms of tooling available, I've just got some jack stands and my toolbox (sockets / wrenches).
edit: I've seen RobertDIY's quick video on it and the actual replacement doesn't look too awful.
How bad a job is it to diy replace the main crank seal?
- TheMrFailz
- Year and Model: 2002 V70 2.4T
- Has thanked: 7 times
- Been thanked: 2 times
Professional jerry-rigger.
- Been thanked: 4071 times
2002 with VVT?
Not bad with the lock tool to keep things locked up.
Where are ypu in NY in case you need moral support?
I’ll PM you my coordinates
- Been thanked: 504 times
- Replace the PCV system first to reduce the crankcase pressure. This may slow down the RMS leak quite a bit.
- Then if it is still bad, then replace the RMS, use only Volvo genuine seal.
- TheMrFailz
It's on the front side. I mighta used the wrong terminology there.cn90 wrote: 31 Oct 2018, 18:10 - Replace the PCV system first to reduce the crankcase pressure. This may slow down the RMS leak quite a bit.
- SuperHerman
- Been thanked: 207 times
If it is the front seal (oil pump) it is basically like doing a timing belt. This is on the passenger side. It can be done with jack stands.
If it is the rear main seal (driver side) that is a different and more involved.
- TheMrFailz
Oil pump side. If it was the rear it'd be a dealer trip no question.SuperHerman wrote: 31 Oct 2018, 18:26 If it is the front seal (oil pump) it is basically like doing a timing belt. This is on the passenger side. It can be done with jack stands.
- SuperHerman
Look up timing belt replacement. You will see the offending seal once the harmonic balancer is removed (if I recall correctly you have to pull off the sprocket which is not much added work).
If you think you can manage the timing belt and abscate comes by you are home free.
- Year and Model: Lots
- Been thanked: 128 times
If it's a turbo 2002 the seal that usually plays up is the non VVT intake side. Very easy to replace and in.some instances they can be popped back in with some carby cleaner to clean up the head and seal and 2 large flat screwdrivers.
FRONT crank seal rarely leaks before 200K miles.
Rate of oil leak (i.e. How much oil is lost per min) depends on the location. As mentioned above, the VVT seal rate of leak can be very baaaad!
- TheMrFailz
Well I mean I'm at a 184k so I'm not too far off from there. Wasn't able to investigate as it was pouring today and I don't think my engine bay needs to be waterlogged in addition to caked in oil but come tomorrow I'll see what's up.cn90 wrote: 01 Nov 2018, 16:50 FRONT crank seal rarely leaks before 200K miles.
edit: I was loosing about a quart a mile at 30 mph.
- 10 Replies
- 4334 Views
- 8939 Views
Last post by cn90
- 9760 Views
Last post by tyguyc
- 22 Replies
- 10510 Views
Last post by ggleavitt
- 203 Views
Last post by AfonsoF1999
