Hi, guys. I’m new here... I have a 95 850 GLT 5-speed (non turbo) and I’ve been having some issues: first the alternator went so I replaced that, then I’ve been having this issue when I shift the car is sluggish and the rpm’s go up and down, I changed the coil, cleaned the air filter and the mass aid flow sensor and nothing changed; The check engine light just came on but I can’t check the codes because my obd-1 seems to have shorted out, I plug in the (repaired) jumper wire and the light glowes, I push the button and it glowes brighter but I don’t get any codes flashing. It has 355K on it but has always been maintained and has served me well as the third owner. I’m sure it’s something easy (I hope) but I could use some help.
Thanks in advance...
OBD-1, a 1995 850, and troubleshooting RPM bounce
Blackwagon
- Year and Model: 95 850
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'95 should have both...ObdI under the hood and ObdII in the center console under the coin holder.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
not all 95s had OBD 2. My 95 NA with Fenix had no OBD 2 Port.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
95 GLT is 2.5 20v car....10v cars have Fenix management and they are GLE.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Blackwagon
No, the only one is under the hood.
- misha
Are you sure?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Blackwagon
Nope. I have an ash tray there.
Blackwagon
It’s a 5-speed so the set up is a little different.
- misha
All of them are 5speed manual and 4speed auto from the factory.
That coin holder is UNDER the ashtray.
All U.S market '95 have both...obdI and ObdII....are you sure it isn't '94?They didn't had obdII.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Blackwagon
Here ya go...
- 12 Replies
- 1153 Views
Last post by firstv70volvo
- 35 Replies
- 2966 Views
Last post by ZionXIX
- 1112 Views
Last post by dikidera
- 669 Views
- 13 Replies
- 1571 Views
