How long do Bilstein HD's last?
clarkerussell
Year and Model: 1998 S70 GLT
Has thanked: 20 times
Been thanked: 4 times
Post by clarkerussell »
Hello all,
My 1998 S70 GLT with 288K miles needs new strut bearing and spring seats. It has Bilstein HD's that have about 170K miles on them. I'm assuming they need to be replaced, but before I pulled the trigger, I thought I'd ask for a second opinion...
I asked Bilstein about their "Lifetime warranty" but they said it didn't cover wear and tear, and if I got 170K miles out of them chances are there is no manufacturing defect so they wouldn't replace it. Any thoughts on this?
Clarke
clarkerussell
One more question, how long should OEM springs last? Should they be replaced after 288k miles?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Put your knee on the bumpers and put your weight on it all at once, then notice if it comes up and stops or comes up and down, "bouncing". Bounce means the Bilsteins are done.
Springs I'd leave alone unless one is broken, or you want to lower it.
Also -> Amazon link
Has thanked: 2199 times
Been thanked: 1852 times
Bilstiens are good shocks. Mind you HD's are too hard for road use. My 00 'R' came with them and they were horrid on our rough roads. Managed to break the valving in one driving over a deep ice rut in our neighborhood. Replaced with Tourings. Mush nicer for everyday use in my opinion.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
scot850 wrote: 04 Nov 2018, 22:20 Mind you HD's are too hard for road use.
Most any suspension part designated 'HD' is risky. Suspension is tuned by engineers through a highly sophisticated software environment and extensive road testing. Change anything - dynamics/resistance to motion, weight, tire characteristics or pressure - risks all your little Volvo hamsters to jump ship and start forming picket lines. You know when you start running over them. It feels awful.
Has thanked: 1609 times
Been thanked: 4065 times
Someday I will have to pull ,y T5 records when I refreshed at 160k because I have mine dialed in perfect , for me
IPD blue springs in rear
Sachs struts in front, springs??
clarkerussell
I'm assuming these are HD's as they were purchased from IPD back in 2005 (for only $126 back then!).
I removed them from the car yesterday and the bearings were REALLY bad and the bump stops had disintegrated, but the shock body was clean and no oil leaking that I could see. I don't know if I should just get new seats and bearings and put them back on, or if I should replace... I'd like to send them to Bilstein for evaluation, but they keep sending me to IPD and IPD sends me to Bilstein...
Has thanked: 311 times
Been thanked: 817 times
If they are black they are Tourings, if they are yellow they are HDs. Year of purchase doesn't matter.
clarkerussell
erikv11 wrote: 05 Nov 2018, 18:02 If they are black they are Tourings, if they are yellow they are HDs. Year of purchase doesn't matter.
Sorry, I meant to say they were yellow.
Silvershield82
Year and Model: 2010 Volvo XC90
Post by Silvershield82 »
I agree that the HD's are too stiff. If you're okay with that, then go for it. Bilstein shocks is a good product but it still depends on your preference. As for the springs, better to keep it as is unless you also want to do a mod on the suspension.
