The repair you already did to the fuel line looks fine to me. You used the correct type of clamps. The trick is to get the size of the barb connector just right. For extra insurance I would have probably used some sort of RTV rated for fuel under the assumption that I would never have any reason to take it apart. If the barb connector pushed on fairly tight before tightening the clamps it should be ok.chrisobics wrote: 05 Oct 2018, 09:19 no I did that myself. that line was also damaged by the nice or squirrels. according to S.U.R.R. this is how to repair plastic lines. They are a company that specializes in fuel and brake lines.
The repair you're going to do to the evap line should be fine with plastic vacuum type barb connectors and regular low pressure fuel line hose. You just need to make sure it's absolutely sealed up air tight.
