2006 V70 brake Vacuum pump/switch 31317445 31265825 Topic is solved
No Brakes When Cold, Volvo V70 Vacuum Pump
- Has thanked: 1611 times
- Been thanked: 4071 times
My 2005 NA has the brake booster pump.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
all s40/v40 2000-2004 had them. 4 cylinder engines have too low vacuum idling, a/c on, in gear, and cooling fan running for brake booster.
The others starting 2002 got them.
Dual cvvt engines have very little intake vacuum when started cold due to the radical cam phasing and retarded ignition timing, both for catalyst and engine warm up speed. CVVT on either or both cams is utilized for quicker warm up and hotter initial exhaust temps. All can have marginally low vacuum when cold to support brake booster for easy pedal.
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
On my 2007 2.5T I thought I had a vacuum pump/switch problem, since recently on 2-3 occasions when starting from cold, AC on I think (warm outside if I recall correctly) and driving away quickly, reverse first to turn around, then drive. I had a stiff brake pedal and almost no braking. It always resolved itself in ~15 seconds. This first happened about 6 months ago. Then I found this thread and ordered a new switch and pump and went to put them in yesterday.
Digging into it what did I find? The dang pump plug was disconnected! The pump hadn't been running at all for several months or more. Braking has always been mostly fine.
Interesting that there is no error code thrown for not having the vacuum pump plugged in.
So, now I have a brand new pump and switch out of the original packaging. I'll sell cheap to anyone interested, PM me.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There is a chance the previous owner disconnected the pump because it was running too much. This happens when the booster seal at the pedal fails and starts leaking. I have 1-2 videos on youtube on the subject.
Bump for book keeping and parts numbers
Excellent thread with pics and diagnostic skills!
zanzabar
Good point! I already bought the grease, I'll go inspect and lubricate that seal asap.oragex wrote: 13 Nov 2018, 00:43 There is a chance the previous owner disconnected the pump because it was running too much. This happens when the booster seal at the pedal fails and starts leaking. I have 1-2 videos on youtube on the subject.
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
- Has thanked: 311 times
- Been thanked: 817 times
This thread and the videos from oragex really helped for troubleshooting when my 06 S60 turbo had the same problem.
I fixed it with a booster pump from the junkyard, scavenged from an 08 V50: viewtopic.php?f=9&t=85448
pdr1966sc
- Year and Model: 2006 V70R
- Been thanked: 2 times
Schematic of this?
I am having a brain cramp here -
The orange connector shows 12v - key on - on one pin.
When the Vac switch is electrically closed, the 12v is then fed to the Vac Motor - but I only see one wire (harness of 2) going into the motor.
There must be a little more to this good thread than is shown??
On my car the 12v hot is on the orange connector with key on, but shorting across the orange connector did not result in the pump running (and it is very likely it is worn out...anyways) as I am trudging through a 'new to me' car.
Does anybody have a wring diagram, atleast this is all easily accessible so I may just pull the pump and bench test/dissassemble.
Sounds like a dead pump, if you're not getting the info you need from the first page of this thread (sorry I did not review it just now to sort out your comments
) then I would just pull the pump, removal is super easy. Test the pump on the bench with 12V.
- To release the vac line on the brake vacuum pump, press on the green connector tab while pulling the hose off the pump nipple.
- To remove the pump, unhook the bracket (2 bolts, they use a 10 mm socket) and drop the pump down while still attached to the bracket.
- To reinstall the hose, just push it on until it clicks.
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
Great video. I did watch Your previous one about lubricating the brake booster seal and ordered the PTFE/ silicon lube from EBay, because you’re mentioning being slightly thinner versus the Volvo lubricant
Do you still recommend using this, it will be delivered next week.
(Item Name: Lubricant TF - Grease Paste -Teflon grease - Ingredients: PTFE , silicone - 3,5g
Item# 263549953669)
Thanks much,
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
- 11 Replies
- 6978 Views
Last post by Memark
- 2632 Views
Last post by DraftyBread
- 952 Views
Last post by volvo2006taj
- 937 Views
Last post by EstVolvo
- 2881 Views
