98 S70: Water in driverside tail light, how do I fix it?
utilityaudio
Year and Model: '98 S70 GLT
Has thanked: 36 times
Post by utilityaudio »
Hi folks,
I have a ‘98 S70, with water in the Driver’s side tail light, it may have started as early as the spring (first time the dashboard indicated a bulb needed replaced), but recently (last two weeks) it’s been extra rainy, and things have gotten weird.
When applying the brakes, my instrument pannel left turn indicator is very faintly lit, if the left turn signal is on it stops working when brakes are applied, and the Bulb replacement light blinks as the turn signal turns off.
So, the water is causing a short, and I know that’s bad.
If I use some flexible tubing and suck the water out of the lens, the short doesn’t happen. But, as I said, it’s been rainy, and this is only a temporary fix.
What should I do to fix this?
Thank you for your time!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Replace the light assembly.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
The seals for the light have failed and are letting water in (obviously). You might be able to get a new seal, or seal it up with some silicone. Or as rspi suggested, replace the light assembly. If you don't want to buy new, easy to grab from a junkyard or find on ebay.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
utilityaudio
WhatAmIDoing wrote: 18 Nov 2018, 19:34 The seals for the light have failed and are letting water in (obviously). You might be able to get a new seal, or seal it up with some silicone. Or as rspi suggested, replace the light assembly. If you don't want to buy new, easy to grab from a junkyard or find on ebay.
Thanks, I’ll try gently taking the lens assembly out and seeing if there’s anything obvious I can smoosh some RTV on. New lenses from eEuroparts are ~$120 shipped, and the outer surface of this lens looks fine.
Found a vid on youtube (oddly enough, not a RobertDIY vid) going over the removal process, seems pretty straight forward.
Has thanked: 1611 times
Been thanked: 4074 times
I think I still have a tail light from my 99 parts car in Classifieds. I drive BOSTON to pHL weekly so can save shipping too.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
120 bucks is a lot. 35 bucks from salvage. If using sealer hit the 4 corners hard and clean well, I expect it's the corners where the leak(s) are. Might get it done for a few bucks. Seal well around the bolt insert areas. Don't over tighten or you will crack the housing.
