fuel abd evap lines needed
davidrjurman
Year and Model: 02 s60, 96 850, 98 v
Has thanked: 5 times
Post by davidrjurman »
Does anyone know where I can get the fuel and evap lines from tank to engine for a 98 V70 AWD
VIN YVILW5642W2416056? New, Good used? :(
Everything is rotten thanks to the crud the state of CT dumps on the road.
I found the driveshaft I needed, and noticed the leak.
DEALER NLA
Don't want to lose the car, and have to pass emissions.
On another note, this is some of the most Fk'd up fuel routing I've ever seen.
Thanks, David
Has thanked: 1611 times
Been thanked: 4072 times
You will have to make those up,from hard lines and bend to fit if NLA
Save the last bit of your old ones and just swage new line in
They are very high quality so a junkyard pull would work too.
davidrjurman
Thanks, I've tried scrapyards, apparently there are a couple differing versions. High quality or not, what ever CT is dumping on the winter ice is killing all my cars. I guess match and bend is the option to go with. 304/316 stainless tube should last forever. Makes me wonder why they dont use it to start off.
Even 316 will be killed by road salt - especially the CaCl2 spray stuff. A new piece of 304 or 316 will last decades though.
