On my 95 T5M Wagon I´ve had a bucking issue at part throttle ever since I got it a year and a half ago.
The issue is that when I get on and off the gas it bucks, is sometimes a bit rough when trying to hold constant rpms in the 2-3000 rpm range, but feels super smooth under under boost.
So far I replaced or swapped in known good parts from my 96 R:
- Volvo Turbo plugs, gapped .28
- Dizzy and rotor (Bosch)
- Bougicord wires from 2016
- new throttle position sensor
- MAF sensor from the 96R (might be the original one, but the R runs really nice)
- cleaned PCV
- inspected all vacum hoses and sprayed them with brake cleaner. seem to be good
- sprayed intake manifold with brake cleaner. gasket seems good
- replaced the timing belt and tensioner and the pulleys. I locked the cams to the old position.
I get nice boost, no CEL on.
A Volvo mechanic I asked the other day said to double check the timing marks. And it looks like one is a tooth off.
Before throwing more money at parts: Could the timing being off cause theses bucking issues?
I guess yes, but what do I know?
Timing belt 1 tooth off - could this be my problem Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes it can....timing is the most important for engine to run properly.
When you re-set timing,remove negative battery cable for 15min in order to reset fuel trims....again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Mkay... nothing like wrenching in the freezing cold ...
I guess I can get away with temoving just the tensioner and pulley, I guess.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
If it's hydraulic tensioner...it's the only thing you actually need to remove.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Now that I am about to tackle the job. I aligned the crank on it´s mark and the exhaust valve looks to be quite right but the intake looks off by about a tooth.
The red marks align, but they might have been from a previous TB job done wrong, I just mistook them for the red factory marks when replacing the TB this summer.
Should I try to set the exhaust one tooth back or is this what it should be?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
Allign exhaust and intake with grooves on a plastic cover.
From the picture it looks that both are a bit off....but it could be a bad angle the picture was taken.
Intake a little back and exhaust a bit more back....check the crank..put the belt...re-check.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
I aligned the crankpulley again with my worklight and took another photo. This actually looks quite right to me.
So off to another round of guessing what causes the car to buck, because the timng belt can be crossed off the list, I´d say.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Year and Model: Many Volvos
- Been thanked: 76 times
Looks spot on.
I have had two of them that were a full tooth off on both intake and exhaust when I went to do the first timing belt change after I bought them. It isn't as uncommon as you might think. The cars ran OK even with the timing off but ran better with it correct.
- misha
Don't forget to reset fuel trims after timing belt re-check by disconnecting neg.batt.cable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3052 Views
Last post by erikv11
- 1119 Views
Last post by Cees Klumper
- 12 Replies
- 7125 Views
Last post by oragex
- 9416 Views
- 9 Replies
- 552 Views
Last post by jonesg
