1. I've been noticing this often, but when I hit a pothole or a bump very hard, the respective wheel will rebound and a weird whirring noise will start, and I'm not exactly sure how to describe it. It usually lasts around 3 seconds and stops.
I was thinking it had something to do with ABS or Traction Control.
2. Another thing, whenever I start my car, it smells extremely rich. It's as if the exhaust smells like a gas station; huge amounts of smoke appear (white smoke), for a few seconds, and then the smell begins. Is there a way to tweak the amount of fuel vs air? Maybe the engine is running rich.
1998 Volvo S70 - Noise from Suspension
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
There is a cold air pump which is supposed to operate when you start your car. The pump turns off after a minute or two. It sounds like your air pump is not working, allowing a very rich condition to heat up the cat and exhaust rapidly.
As for the 3 second noise when you hit a bump? Still too many possibilities to list.
Klaus
Klaus
Klaus
- Year and Model: Many Volvos
- Been thanked: 76 times
Also check for a fuel injector seal leak if you are smelling it inside the cabin.Another thing, whenever I start my car, it smells extremely rich. It's as if the exhaust smells like a gas station
If the pump is the problem, I see no point in spending 400 bucks for a new one. The car runs perfectly, except that smell at start-up. Nothing gets into the cabin, it's just that smell in the first 10 minutes after start. Anything past 10 minutes of running smells normal. Now, the worry...does it affect overall fuel economy? I've been getting terrible fuel economy lately.Klausc wrote:There is a cold air pump which is supposed to operate when you start your car. The pump turns off after a minute or two. It sounds like your air pump is not working, allowing a very rich condition to heat up the cat and exhaust rapidly.
Klaus
As for that noise, its a quick whirring noise, like a mechanical sound. Imagine scratching an old washboard at high speed for a few seconds. That kind of sound, but much much faster, only for three seconds.
Another thing, over every bump, my hood rattles...a lot. Is something broken, since I can't find anything wrong with the latch? It's just loose on the left and ride front corners and moves up and down ever so slightly.
1998 Volvo S70 N/A 75K Miles
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
If your mileage has gone to pot and you have pretty high mileage on your car (over 100K miles) then I would say it's probably time to change out your front 02 sensor. About the hood rattling. I had this too...it wasn't the latch. It seems that the rubber bits that buffer the hood wear down after many years. I just rubber cemented some more rubber pieces onto the ones there (they are square- you'll see them) and no more rattle.
" I've been noticing this often, but when I hit a pothole or a bump very hard, the respective wheel will rebound and a weird whirring noise will start, and I'm not exactly sure how to describe it. It usually lasts around 3 seconds and stops. "
Does it happen only when you have your foot on the brakes? If so, it is the ABS.
I've seen possible so many of these cars with failing or failed air pumps and have never seen smoke come out of the tailpipe because of it. But when the pumps fail, it can because they get filled with water, so maybe it is pumping water into the exhaust? You can disconnect the pump hose to the check valve and see if the smoking stops.
B
B
Well, my mileage is only 84,000 Miles, which is substantially low, so I doubt its the O2 sensor, unless worst case, it's gone bad.MadeInJapan wrote:If your mileage has gone to pot and you have pretty high mileage on your car (over 100K miles) then I would say it's probably time to change out your front 02 sensor. About the hood rattling. I had this too...it wasn't the latch. It seems that the rubber bits that buffer the hood wear down after many years. I just rubber cemented some more rubber pieces onto the ones there (they are square- you'll see them) and no more rattle.
Thanks so much with the hood issue, it certainly stops an annoying noise from the bumpy roads around here.
Thanks! I suspected the ABS or something, but wanted to make sure it wasn't something bad. Yes, it only happens when I'm on the brake and hit a hole, which proves that my ABS still works. I guess the wheel looks for traction while I'm braking and engages ABS to compensate.tripleb wrote:" I've been noticing this often, but when I hit a pothole or a bump very hard, the respective wheel will rebound and a weird whirring noise will start, and I'm not exactly sure how to describe it. It usually lasts around 3 seconds and stops. "
As for start-up smoke, it still happens if I disengage the hose. The exhaust has a strong fuel smell, which I've not noticed until recently.
- 12 Replies
- 3362 Views
Last post by RickHaleParker
- 1233 Views
- 3256 Views
Last post by mtd240
- 1400 Views
Last post by Ocelot
- 15 Replies
- 3444 Views
Last post by dosbricks
