volvo airbag delete Topic is solved
NYCKID221
Year and Model: 1998 s70
Post by NYCKID221 »
[quote=NYCKID221 post_id=489295 time=1543444876 user_id=99638]
is there a way to delete the airbag system and bypass so the light wont show up?
looking to put a momo steering wheel and a set of vdo gauges
Has thanked: 312 times
Been thanked: 818 times
misha wrote: 29 Nov 2018, 05:23Nope!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
NYCKID221 wrote: 28 Nov 2018, 15:41 is there a way to delete the airbag system and bypass so the light wont show up?
It's not my concern but...I can't understand that you want to remove a steering wheel with airbag because of MOMO sport steering wheel.
Why would you risk your safety?
Unless it's strictly a racing car for a track only,with roll cage and stuff.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2215 times
Been thanked: 1853 times
If the light is on, just removing the bulb will still leave the whole system disabled. So if you don't want any airbags, then easiest is to pull the bulb but knowing you are losing all airbags. Your choice. Hopefully if you sell the car on you can give the new owner an honest heads up and choice to re-fit the original and have the working system again.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I agree with the others. Not sure why you would replace the wheel and disable airbags unless you were building a proper race car. But if you really must have a race wheel, either live with the light, tape over it, or pull the bulb.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Warning: anytime you mess with the SRS system you risk setting it off, proceed at your own risk.
Disassemble the OEM steering wheel and locate this component it is called the Contact unit and should be attached to the bottom of the OEM steering wheel.
There should be a Solid Black wire and a Solid Orange wire on the wiring harness side.
1. Measure the resistance of the Contact unit across the Black and Orange.
2. Place an equivalent resistance across the corresponding Black and Orange on the wiring harness that remains in the car.
If all goes well this should fool the SRS control module into thinking the SRS steering wheel sensor and air bag is still there.
Active
Past
misha
Post by misha »
Carefull....resistance measuring with a multimeter can lead to airbag deploy!
There is a statement about that,somewhere in Volvo SRS documents.
No measurements of any kind should be performed in SRS system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
WhatAmIDoing wrote: 30 Nov 2018, 00:36 I agree with the others. Not sure why you would replace the wheel and disable airbags unless you were building a proper race car.
You know why, it's a wanna be race car driven on the street.
85 GLH, 367 whp
00 Insight, 72 mpg
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
[quote=tryingbe post_id=489459 time=1543592038 user_id=20934]
[quote=WhatAmIDoing post_id=489427 time=1543563414 user_id=91601]
[/quote]
[/quote]
A little harsh?
But if this is the case, Volvo makes the car for you and it is actually safe! V60/S60 Polstar. For 2015 0 to 60 4.5 seconds, and stopps from 70mph 149 feet due to specific breaking system not on R or any other factory Volvo even with "Polstar" factory tune. I really thought about ordering the V60 Polstar in 2015, but sadly all 80 V60's for the US market had already been sold... June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
NYCKID221
Post by NYCKID221 »
https://www.youtube.com/results?search_ ... bag+delete
thanks to all that tried to help without bs.
found the answer. posted link for other members that might want to do this
