225/55R17 tyres on V70
volvoadventures
Year and Model: 2006 V70
Has thanked: 6 times
Post by volvoadventures »
My 225/45R17 tyres on my 2006 V70 need replacing soon, I'm considering a higher profile 50% or 55%
Anybody has experience with 225/50R17 or 225/55R17 ? My wheels are Otrera 7.5" wide.
trilladelphia
Year and Model: 2004 V70
Post by trilladelphia »
i have these and love them with the pegasus rims
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The higher the speed, the more the speedometer will be off https://tiresize.com/speedometer-calibration/
But a taller side wall will always give better comfort on a 17in wheel..
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
If you go with a different Aspect Ratio and don't want to throw off your speed indicator and odometer. You will need to go with a smaller wheel and/or a narrower tire.
For example:
With 225/50R17 your speed and distance would be 3.5% higher then indicated.
With 225/55R17 your speed and distance would be 7.0% higher then indicated.
With 205/50R17 your speed and distance would be 0.4% higher then indicated.
With 185/55R17 your speed and distance would be 0.15% higher then indicated.
With 225/50R16 your speed and distance would be 0.4% lower then indicated.
With 225/55R16 your speed and distance would be 3.0% higher then indicated.
Another possible option is to reprogram the car for a different tire size. Somebody with a P2 would need to look in VIDA and see if the tire size parameter can be changed without a software update. All my Volvos are Bosch Motronic 4.4 or Siemens EMS 2000.
Active
Past
oragex
Post by oragex »
Wanted to add that usually - not sure if everywhere around the world, the factory tire size specification is to be found behind the gas filling door. That tire dimension (including the tire wall size) has been used to calibrate the car speedometer.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I'd stick to 50 profile at most to keep reasonably within specs for circumference.
volvoadventures
Thanks to all feedback, I do realise that speedo wil be off, I can compensate for that with a tiny sticker on my speedo, or use my GPS.
I'm interested in actually experience with these higher tyres on my 2006 V70, rear wheels should be fine but front tyres will they rub when cornering ? I drive with light loads, never have passengers.
volvoadventures
cbpitt01
Year and Model: 2006 V70 2.5T
Been thanked: 4 times
Post by cbpitt01 »
My 2006 V70 has the Orpheus 17x7.5 wheel, and the tire sticker in the door jamb calls for (and I have the wheels fitted with) 235/45R17. Tirerack.com lists that as the only available-from-the-factory 17-inch tire size, at least here in the states. If that was your case, I would think you could go down one size in width, while going up one size in aspect ratio, to 225/50R17. But you’re saying you already have 225/45R17 tires fitted. Was that the factory-installed size on those wheels? Maybe the factory tire specs are different than the US models?
2006 V70 2.5T, Ice White with Arena/Oak, bought “newsed” @ 183,500 miles in Dec 2015; 244,000+ as of 12/23/2020.
