2001 V70XC - Leak at radiator hose to thermostat Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
190,000+ miles. The task to remove and install radiator is not difficult. The two replaced in our '87 850 & 2013 XC90 were Volvo.
I found radiator made by Nissens, Behr, and TYC. I stick to Volvo for critical functions and 100% out-of-the-box fit. But happy to take your recommendation for a best match.
Happy Holidays.
Has thanked: 1609 times
Been thanked: 4065 times
Just make sure the radiator is mounted solidly and the engine mounts are solid. Engine torque on the radiator snouts will break the plastic side tanks from the metal radiator seal in short order. Mine took only 3 years
boostedxc
Year and Model: 2004 XC70
Post by boostedxc »
I got an extra OEM one that will fit your car I'd sell for cheap. let me know if you're interested. [email protected]
xHeart
Post by xHeart »
abscate wrote: 01 Dec 2018, 15:25 Just make sure the radiator is mounted solidly and the engine mounts are solid. Engine torque on the radiator snouts will break the plastic side tanks from the metal radiator seal in short order. Mine took only 3 years
Small coolant lose. I am noticing coolant residue just below the upper trans-color line. The rubber hose below that is connected to condenser is wet from the drip.
This is a persistent slow leak since the install -- replacement Volvo radiator pn 31319056.
xHeart
Post by xHeart »
The coolant escapes at the reservoir overflow nipple. Every few weeks the level drops to min. Blue/Green residue collect at the reservoir seam. Is the hose failing?
Found wetness and crystalized residue at the connection, the clamp is at max. Is the hose failing or the reservoir cracked?
Probably cracked reservoir. I remove it and inspect under bright light
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
You can cut off the 'molded' end of the hose that connects to the overflow jar, then push it back on and snug it back up.
xHeart
Post by xHeart »
reverend wrote: 10 Oct 2019, 19:34 You can cut off the 'molded' end of the hose that connects to the overflow jar, then push it back on and snug it back up.
This is original hose -- maybe dried and hardened. A good weekend for this maintenance.
xHeart
Post by xHeart »
xHeart wrote: 11 Oct 2019, 13:47
Cut off 1" from the bleeder hose at the reservoir and reconnected. The wetness was visible at the either end of the bleeder hose, reservoir and radiator respectively.
xHeart
Post by xHeart »
This thread is reverted to UNSOLVED since the slow escape of coolant continues.
What's best type of hose to purchase from the auto parts store to replace the bleeder hose -- ID, material, etc?
