Oil in my valley '04 V70 NA
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
This car is "new to me", so I know nothing of it's history. I did buy it from the original owner who allowed he "wasn't much for maintenance". 115K miles. I just got it home a few days ago. It required the immediate replacement of a coil, while I was at it I decided to replace the plugs. When I took off the cover, I noticed oil in the valley between the cams. This seemed to be mostly near the "rear" camshaft. As I pulled the plugs (I assume they were original), I noticed that 1-4 were saturated with oil.
Is this condition at all normal? Does it result from spill at the oil fill? Is there a cure?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
It's quite possible it's from spilled oil, yes. So clean it up and check again in a little while as a first step before getting too worried.
Been thanked: 4065 times
I get this on top of my 1999. It comes from the oil filler cap, so you can try a new gasket to try reduce it. It helped a bit on mine. The best test is clean it off with paper towels, remove the plastic cover , and watch the top to see how the oil accumulates...if it starts at the middle front and works outwards it's the oil filler cap
Been thanked: 504 times
Post by cn90 »
Leave the cosmetic cover off, store it on your garage shelf.
Replace the oil cap Gasket.
Faust
Post by Faust »
An ethical question. When I cleaned out the console, I found three ladies Timexs and a Rolex. Do I keep the Rolex?
2004 V70
If you do, some gets your soul. You should know that.
Seriously, call the PO. Only good can come out of that.
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 02 Dec 2018, 16:08 If you do, some gets your soul. You should know that.
Put it like this:
" what do you want me to do with these crappy old watches"
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Wasn't "Oil in my Valley" a sweeping epic western based in Texas....?
Has thanked: 311 times
Been thanked: 817 times
A Faustian bargain plays out right here on MVS!
Paramount point about the oil in the valley: given the history I would immediately suspect it is due at least in part to a clogged PCV, and do a glove test.
Faust
Post by Faust »
"Wasn't "Oil in my Valley" a sweeping epic western based in Texas....?"
Not sure, the phrase simply sprang full blown in my mind, much like Venus from a Cypriot sea.
2004 V70
