Kallekula's $160 V70 2001 Topic is solved
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Neighbor was about to sell her wagon to the junk yard but I bid $10 more and got it😀
It’s not a pretty car but I will try to freshen up the interior a bit. Engine, tranny and AC works fine. It has 180k on the odometer.
It had an awful pulsating/grinding noise driving on the freeway so I replaced the front wheel bearings. Of course it was the rear ones that were failing😕
Has two codes for evap leak and cat efficiency. Found a disconnected hose under the vehicle so that might fix one of them. About the cat, I’m doing something I read about but haven’t tried yet. Spacing the downstream O2 sensor with some spark plug foulers. Just hope the cat isn’t too far gone to pass smog.
Some pictures:
BMW 540i 2002
S70 Base 2000
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Good luck with the project :)
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Nice find. N/A ? www.youtube.com/watch?v=gOx3Q8vqoz4
Nice seat cushion swap
The cat may be the rear O2 sensor, a broken flex downpipe, or a fouled cat (acetone may fix it)
kallekula
Post by kallekula »
oragex wrote: 18 Nov 2018, 12:21 Nice find. N/A ? www.youtube.com/watch?v=gOx3Q8vqoz4
Yes it’s a non-turbo
BMW 540i 2002
S70 Base 2000
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Before adding the spacer (foul plug), I would work through all possible causes. Throwing in the spacer may turn off the light, but end up ruining a good cat and yielding poor performance and mpg. In the end the emissions will still be failing - so it may not work depending on how the testing is performed in CA.
Start with what has been mentioned. Look for leaks, sensors that are failing/failed and then visually examine the cat for damage. Once you have the rest sorted and you know the engine management is properly functioning would inserting the foul plug make sense.
Car is a nice score.
kallekula
Post by kallekula »
Yahoo! Ready for smog!👍
BMW 540i 2002
S70 Base 2000
Been thanked: 4068 times
You guys in CA don't get any protective coating on your suspension parts, do You?
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
"You guys in CA don't get any protective coating on your suspension parts, do You?" Funny things happen in California. For instance, in the '60's MB sold "California Coupes", a hard top, but no soft top. I guess "it never rains in California".
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
SuperHerman
Curious if you got the car operational with or without the defouler plugs.
The test results you show are from what source? What I am most curious about is if you use the defouler plugs - does the car still pass emissions or is it just beating the computer you are using.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
abscate wrote: 02 Dec 2018, 04:49 You guys in CA don't get any protective coating on your suspension parts, do You?
Ha, I don't know if you're being sarcastic or there really is protective coating for suspension parts. I have never heard of that :)
