Stumped on Electrical Connector
yabadabadoo1026
Year and Model: 2001
Post by yabadabadoo1026 »
not the unhandiest guy around but too often stumped on electrical connectors since on different cars I see different ones and often an exercise in futility figuring out how they separate.
Wanting to so a simple replacement of oxygen sensor on 01 S60 and I could piddle with this connector forever and still not have a clue how to separate--------so frustrating when something that should be simple becomes the hardest most time consuming part of a simple job.
The attached pic is not the connector for the sensor just one that looks like it that I could get a decent pic of. Can someone pleeeeeze tell me how this separates
, totally stumped by it all
jimmy57
Been thanked: 322 times
Post by jimmy57 »
Push the bar in this view opposite the part of connector where the red mark is located.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As mentioned, depress in the midle of the bottom of the U, depress with a screw driver while pulling on the connector. Even better ask someone to pull 9n it. It may be a bit stuck.
Has thanked: 1609 times
Been thanked: 4064 times
These things can drive you crazy. On the other hand, Volvo makes some of the most reliable connectors there are.
Try pushing it together when you depress the lock tang (above) then pull it apart.
it took me five years to learn this.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Depress the jail cell and pull on the rocket boosters!!
